Onan 7.5 MDJE 3CR/2268AB New Toy
this thread has 128 replies and has been viewed 5926 times
Old 04-05-2017, 06:21:54 PM
len k len k is offline
Default Re: Onan 7.5 MDJE 3CR/2268AB New Toy
Looks nice, control box looks pretty pristine too.
Could still be the valve seats cruddyed up
Originally Posted by PnishrPW View Post
Glow plugs show resistance (.9 on manifold/1.8 on other 2).
Interesting ,,, at 12V that's ~27 amps total.
On a DJB someone tested it and measured 50 amps total ( I assume that was 12 VDC.)
Old 04-05-2017, 07:47:56 PM
Richard L Richard L is offline
Howdy,
Doesn't look to be in that bad of shape.
Have manuals and a Onan Training Manual that was given out at a class in Sea when these came out in the 70,s, can e mail if you need info.
mvamaunet@gmail.com
Old 04-05-2017, 08:23:49 PM
If it has stood a while there could just be grit and carbon lodged on valve seats, so worth taking a soft hammer or wood block and with valves closed, smack each rocker arm above the valve stem to dislodge crud,and then check clearances. A small shot of oil in each intake port and you may well have it running.
Those DJ series do need good glow plugs and 30 seconds or more of glow time to fire up. No starting fluid if there is an intake heater. Regards,
Combustor.
Old 04-05-2017, 09:05:25 PM
MBB MBB is offline
Try 932-0405 for training manual on http://www.twinslan.net/~n0nas/manuals/onan/
As well as other manuals.
The Following User Says Thank You to MBB For This Post:
Old 04-05-2017, 10:28:25 PM
MBB MBB is offline
Here is the wiring diagram according to the build sheet OnanParts posted.
Old 04-05-2017, 10:44:56 PM
PnishrPW PnishrPW is offline
Thx guys, I don't have a lot of time to spare for this project but you all provide great advice and motivation! I'm picking away at this in literally few minute increments... ex: today I had to run back to my shop twice during the day, each time I spent a 2-3 min spaying and working the small terminal on the starter. Second time it worked loose and came off clean.
After work I had about 30 min before heading to a service call. I pulled the starter and got it on the bench. Pulled the pin between solenoid and linkage, arm and solenoid both slightly stuck. Removed solenoid and freed it up, ditto for starter fork. Going to open solenoid and check contacts and plunger, same for starter - brushes etc. Both are soaking in PB, starter thru bolts are loose - solenoid not so much... Memo to self : buy some tiny a$$ cotter pins... Located a solenoid locally, $36 if I need one. Was quoted $325 for a rebuild!
Also going to pull end bell and have a look see at the bearing / brushes etc. Screws soaking now.
Len, I forgot to factor in .4 ohms for lead resistance - mea culpa!
Thx for info Mike, looking like I may need it soon. I've started a file for the relevant docs, I am having trouble extracting schematics / diagrams from pdf's, can't seem to get it right.
Old 04-06-2017, 09:07:54 PM
rmchambers rmchambers is offline
If you need the raw water pump I may have a kit or two to repair that with, not sure if the impellers are any good though. If this is not going back into a boat I'd do away with the raw water anything and use the fresh water loop to go to a radiator or some other way to dump the heat. Less drag on the engine that way too. Treating the whole thing with PB is a good idea, a lot better than trying to find broken screws/bolts etc.
Robert
The Following User Says Thank You to rmchambers For This Post:
Old 04-07-2017, 11:34:59 AM
We have achieved starter! Got the starter opened up and checked the brushes, they look recent. Commutator needs attention but is serviceable for now. I couldn't get the endcap off the solenoid so I didn't check the contacts. I re-assembled everything and cleaned the terminals as best I could. Put some cables on it and it WORKS. Little balky first couple of tries, but seems to be ok now. Got it re-installed.
Pulled the gen end cap, little rough but nothing jumps out at me. Going to lube the bearing and check field resistance.
Looking like I may try to start it tomorrow, need to disconnect the vr, and check engine electrical first. I've probably missed something on the pre-flight, if I have please let me know...
Robert, I appreciate the offer - but the raw water pump won't be going back on. Bearings seem good, I think what I initially felt was the impeller disintegrating. It feels better now... If someone needs it, PM me! The heat exchanger may also be up for grabs, unsure right now.
ID:	279498   Click image for larger version
Old 04-09-2017, 01:10:45 PM
Going to drive out to shop shortly, ended up working till 9 last night... Gotta find out if Schrodinger's generator is alive or not. If it's alive, I'm guessing it'll be okay to run for 5 min or so with no active cooling? Fresh water system is intact and full of nice green coolant, but no belt. Ambient temperature - 50ish.
Would anyone happen to know what size / type of belt is needed for the fresh water pump? Will only be using 1 pump in stock location.
Any (and all!) last minute advice about waking the beast would be greatly appreciated! Thx, D
Old 04-09-2017, 04:35:36 PM
BigBlockChev's Avatar
This is what is on one of mine, could go 1/2"shorter to be in the middle of the adjustment range. Should be OK to run for a few mins with no cooling. These diesels don't produce much heat at no load. If the heat exchanger is still in place you can run a garden hose through it instead of a pump. Use the manual lever on the pump to purge the fuel till you get no bubbles at the return line , use a piece of clear hose on the return line and leave an up facing loop to be able to see the fuel flow and air bubbles. Glow for a minute for easiest starting. Use a big well charged battery and bolt the cables on rather than using jumper cables if at all possible. So, no air in lines , BFB, and glow for a minute and it should start. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following 2 Users Say Thank You to BigBlockChev For This Post:
onan 7.5 MDJE needs help blaise805 Onan Generators 35 04-20-2014 05:07:10 AM
Onan 7.5 MDJE 3CR/2268AB Charging problems windance Onan Generators 10 04-11-2014 01:21:35 PM
Onan MDJE 6-7.5KW Help Mainshiptom Onan Generators 4 04-19-2010 05:32:50 PM
Onan 7.5 MDJE - 3CR Help LarryGlover Onan Generators 11 07-19-2007 04:38:12 PM
Onan MDJE 6-7.5KW Help Mainshiptom Onan Generators 0 09-28-2005 05:48:23 AM
