Printed Circuit Boards
this thread has 42 replies and has been viewed 1486 times
Old 04-07-2017, 09:03:59 PM
b7100 b7100 is offline
Default Printed Circuit Boards
This thread can apply to anything that has a pc board whether it is a onan generator, garage door opener or whatever. Several years ago I purchased a stair climber off craigs list in like new condition for $600. I used it for 6 months and it quit working. The state elevator laws require a liscenced installer/serviceman to work on them. The require a permit ($300) and inspection. Consequently nobody wants to repair or even sell you parts. After some testing of various switches and components I made a guess that it was a pc board. I finally found someone who would sell me one ($400). It worked for 6 mos then quit. Thinking I bought a dud I bought another one ($400). Again 6 mos it quit. The people that sold it to me said they could come out - remove it (for free) and install a new one for $4000. I got on line and found several companies that rebuilt pc boards. For $80 they would check it out. A week later I learned that there was a missing component causing the failiers. They replaced the component which could probably be purchased from digikey for $5 and charged me $160. Its been working for a year. I feel that I got ripped off for $800 by an industry aided by the state laws. The pc board business is a huge ripoff. $400 or more seems the norm to replace one. They can be repaired for much less. I hope what I have learned about pc boards can be of use to anyone that runs into the high cost of replacing them.
Old 04-07-2017, 09:20:39 PM
Billy J Shafer's Avatar
Default Re: Printed circuit boards
You need to check out Flight Systems. Very good company and they back their work. Plus you can talk to a real person. Not some guy somewhere in somewhere.
Old 04-07-2017, 09:41:44 PM
Probably a MOV, surge protector. Good electrical design engineers add surge protection, and then a bean counter removes it. Someone else with the same unit has never needed a board, and yours dies every 6 months, lol.
Don't forget that they had to fix the problem AND add the component. $140 is a pretty good price. Troubleshooting, repair, and improve a board that I bet they couldn't get a schematic on, is no small talent.
Old 04-07-2017, 09:58:13 PM
I obtained a wireing diagram which I furnished for thier use in diagnosing the pc board. For $160 I was very pleased with the results. The alternative would have been new $4000 stair climber. Getting up and down stairs is gtting very chalenging. It seems as though some people are out to take advantage of someone who has physical limitations for financial gain. It is frustrating.
Old 04-07-2017, 10:25:25 PM
I know what you mean. I am looking for some leg braces. But I think I need a bank loan first. Or learn how to crawl.
Old 04-07-2017, 10:40:59 PM
Big Bird Big Bird is offline
B, it's not just the medical industry that sticks it to you...
I have a 2004 GMC Sierra pickup, the printed board in the instrument panel hasn't worked in 9 years.. the TAC reads 5000 rpm the speedo is stuck at 97 mph the oil pressure gauge sits at zero and the temp gauge never move's.
The only thing that does work it the odometer.
$300. To repair the damm thing, with no guarantee that it will last once you pull out of the parking lot...
Old 04-07-2017, 10:45:54 PM
board repair is getting fairly common. I have a local electrical supplier that has a board repair service. I've had some Cutler Hammer soft starts repaired for @$200. I dropped the board off and 3-4 weeks later picked it repaired. CH had the board as NLA so I was happy to get it back up and running.
Old 04-07-2017, 11:18:51 PM
TLB01 TLB01 is offline
Originally Posted by Big Bird View Post
B, it's not just the medical that sticks it to you...
I have a 2004 GMC Sierra pickup, the printed board in the instrument panel hasn't worked in 9 years.. the TAC reads 7000 rpm the speedo is stuck at 97 mph the oil pressure gauge sits at zero and the temp gauge never move's.
Might not be the board's fault. You live in a warm, muggy salty air place. Check your MOLEX connections under the hood. You might have a connector that, thanks to Florida's air, turned into galvanic action black goop. Once salt water gets into something like the plastic of a MOLEX in a muggy place it never dries out and it just wrecks havoc.
The Following User Says Thank You to TLB01 For This Post:
Old 04-07-2017, 11:31:49 PM
Some pc boards are discontinued so having them repaired may be the only option.
Old 04-07-2017, 11:47:00 PM
BigBlockChev's Avatar
I just repaired a CMQD 7500 HDKAT. The Inverter was dead shorted control power, a replacement inverter goes for about $2K online. Cost $1.44 for a new MOV , , the Red gismo in the pic, exact same part which I soldered in, it was the only thing which showed signs of overheating but the generator was condemned without it . Control power was dead shorted by it, would blow the fuse instantly. Works fine now, I wonder how many other inverter gens were scrapped because of this simple part failure. I have also repaired Onan YD voltage regulators with a few components but found that since all the other components on the board were 25 yrs old too, failure was a frequent occurrence just in a different place. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following 6 Users Say Thank You to BigBlockChev For This Post:
Onan BGD Burning Out Circuit Boards jd2210ct Onan Generators 19 10-06-2013 04:17:51 PM
4.0cck-3cr/12017R Natural gas derating, gaskets, and circuit boards gchank Onan Generators 1 04-28-2013 05:59:11 PM
Any IHC Header printed manuals? Avery22x36 Farm + Industrial Antiques and Collectibles 2 11-26-2010 02:40:13 PM
Onan 4k BGEFA would like to rewire and get rid of circuit boards oldsteveo Onan Generators 9 11-08-2010 09:25:25 AM
Onan 30.0 EK need help finding printed mtl Aaron Gist Onan Generators 6 03-07-2006 09:43:57 PM
