Onan vs. Generac Death Match II
this thread has 40 replies and has been viewed 2042 times
Old 04-09-2017, 02:03:10 PM
Default Re: Onan vs. Generac Death Match II
Specfrickintacular
Old 04-09-2017, 05:27:38 PM
TLB01 TLB01 is offline
Would be more fun to have it catch on fire and blow up while over loaded. Just smashing it is OK, but having it kill itself = win.
Old 04-12-2017, 10:53:10 PM
JohnnyC JohnnyC is offline
Death Match II Update:
Cancel the death Match. As you may know, I got the stupid Generac to run. The problem was the oil pressure switch. No big deal. After putting the dumb thing together, the pull start recoil rope broke. Actually, it was not the rope, but the recoil mechanism. As of now, the rope is fully extended and does not want to recoil back into the mechanism. I don't want to spend too much time of this piece of garbage. I will keep it for now, but I need to keep focus on the JB refurbishing project. Also, Spring has arrive and I got lots of yard work to do...
As a side note, I down loaded the manual for the Generac. I was amazed when I read the "Run Time" specifications (see yellow highlighted line in the picture below). What exactly is the Run Time spec telling me???? I see this as I can only run the p.o.s. at 400 watts continuous (25% of full rated load)and no longer than 5.7 hours??? I must be wrong. Right??
JohnnyC
New Jersey
Old 04-12-2017, 11:00:51 PM
"Run time" in G*****c speak is how long a tank of fuel will last- so if you fill it up it will run 5.7 hours at 25% load, then you are in the dark until you get more fuel in it.
---------- Post added at 10:00:51 PM ---------- Previous post was at 09:58:52 PM ----------
Gotta love that 50 watt reserve for "surge" capacity.
  #25
Old 04-12-2017, 11:30:04 PM
scoops scoops is offline
are you sure that you want to cancel the death match?
i have an aj 2.5 that i would be willing to use as the competitor
i will be in your area next week.
Old 04-12-2017, 11:57:16 PM
Vanman Vanman is offline
Why is it that the spec sheets for this modern junk so rarely states the SPEED?!?
Old 04-13-2017, 05:52:25 AM
Thanks Scoops. There will be time to play after I get the JB painted which hopefully will be no later than 2025.
Where are you going to be heading next week?
JohnnyC
New Jersey
Old 04-13-2017, 11:29:33 AM
Speed is variable, it's an inverter set
Old 04-13-2017, 01:21:51 PM
len k len k is offline
Oil pressure switch must be a common failure on Generac , mine was dead too
(5500 XL, red frame)
Old 04-13-2017, 02:11:39 PM
Ah, even more reason it would be neat to see it. Would be interesting to see the range of speed from no load to full load. Have seen some of these that they allow to scream even more than 3600 rpm. No thank you lol.
Death Match Betting Opens Surfinhurf Onan Generators 393 09-23-2016 08:33:23 PM
ANY old Onan-Rust on stator laminations= death knell? Sunnyside Onan Generators 23 12-15-2015 09:56:51 PM
Generac GP5000 - Ordered new alternator, doesn't match existing casman Generac Generators (SEARS, etc.) 25 12-15-2015 06:34:57 PM
onan 12500 gen code of death, fault 45, perhaps not? mr bridger Onan Generators 2 12-14-2015 06:46:21 PM
Onan green-what's the best paint match B.Ikard Onan Generators 5 09-18-2009 01:04:10 PM
