Onan 4KY Hot Starting
this thread has 11 replies and has been viewed 510 times
Old 04-08-2017, 03:42:34 PM
JNorton JNorton is offline
Default Onan 4KY Hot Starting
I am using this 4KY in place of my 4.0 BF while I rebuild it. Yep, I don't like it either. It runs fine but when I shut it off hot, it will not restart. It will start up if it sits for a good bit. It really gets hot while running but I'm told that they that is normal. Do these have a hot shut down switch? I really haven't tried to trick it into starting yet so I'm just asking if the forum has something to look for before I have at it. Thanks Frank
Old 04-08-2017, 09:47:10 PM
Billy J Shafer's Avatar
Default Re: 4KY Hot starting
From the few that I have worked on. They are hard to start hot. Which is one reason I stopped working on them.
Old 04-08-2017, 10:44:43 PM
nothingbutdarts nothingbutdarts is online now
What about this crappy ethanol gasoline boiling in the carb??
The Following User Says Thank You to nothingbutdarts For This Post:
Old 04-08-2017, 10:50:43 PM
Motorhead's Avatar
Does it have a PRIMER button to prime the carburetor? Most in motor homes, you push the stop button and the fuel pump runs and primes the carb. If you shut down a hot engine, the fuel in the carb will boil out.
The Control panel
and gauges of my
7.5JB
Old 04-08-2017, 11:20:34 PM
I will try pushing it to stop and see if that does it. I'll post an answer when I'm sure. Thanks
Old 04-09-2017, 01:42:10 AM
Motorhead's Avatar
See if it has that feature. If the start stop control is right by the generator, listen for the fuel pump to chatter when you push the stop button. Check you manual and see if you have that feature.
The Control panel
and gauges of my
7.5JB
Old 04-09-2017, 10:42:05 AM
Yes, it has the prime feature. Next time it won't start I'll try it.
Old 04-09-2017, 01:14:36 PM
KPack KPack is offline
Default Re: Onan 4KY Hot Starting
Use synthetic tractor oil in it car oil won't cut it.
Old 04-09-2017, 01:18:00 PM
Here's the one I like.
The Following 2 Users Say Thank You to KPack For This Post:
Old 04-09-2017, 01:21:41 PM
Motorhead's Avatar
Good oil! Have it in my JB, my Honda powered pressure washer and my 4.5hp Kawasaki powered John Deere self propelled mower.
The Control panel
and gauges of my
7.5JB
The Following 3 Users Say Thank You to Motorhead For This Post:
Onan DKD starting rough AKAviator Onan Generators 4 04-17-2016 08:47:49 PM
Onan JC/JB starting nothingbutdarts Onan Generators 20 06-17-2015 02:34:50 PM
Onan 4.0 CCK not starting Ray Griffiths Onan Generators 14 12-04-2011 09:06:11 PM
ONAN generator not starting djsaville Onan Generators 1 03-30-2009 01:45:31 PM
Self starting onan 4.0 CCK wivrrat Onan Generators 9 03-29-2009 01:06:51 PM
