CCK Contractors 569483 from Saint John NB
this thread has 31 replies and has been viewed 1316 times
Old 04-08-2017, 10:08:45 PM
DMeed DMeed is offline
Default CCK Contractors 569483 from Saint John NB
Went on a little road trip today to Saint John NB.
Picked up this little toy
Don't see a name plate or spec tag anywhere - Maybe something will show up under the black coating on it when I clean that off - I think there might be some screen printing under there - any tricks to gently release the dirt without scrubbing the screen print totally off? any solvents in particular to use or avoid? (bit of old gas or diesel on a rag??) (I've got the engine block number in another picture)
The switch appears to have a 8 pin rectangular plug that matches the control box in the background.
It appears to be original twistlock outlets - Not sure that is very useful to me. Will likely want to rebuild that outlet box.
Getting _that_ extended stack into the back of the Rav4 was interesting.
Going to be trying to (very gently) unscrew that back about the first down elbow and replace with some flex!
If you look at the picture of it in the shed below you will notice that stack extended right through a 3" tin can fastened in the wall of the shed to let the exhaust out the back...
Those handles fold nicely out of the way, but I don't like the fact they don't lock in position when exteneded. VERY hard to control the cart.
More in next message...
David M
ID:	279614   Click image for larger version
ID:	279615   Click image for larger version
ID:	279616   Click image for larger version
The Following 2 Users Say Thank You to DMeed For This Post:
Old 04-08-2017, 10:32:36 PM
Default Re: CCK Contractors 569483 from Saint John NB
The original owner was an electrician - he had it all set up in the shed with wires into the house and a list of instructions on the wall by the electrical panel. The current owner (2nd house buyer) didn't want this set - said they are on the hospital grid, so never loose power. (Hospital is just up the hill). Said his new electrician was not impressed with the old set up inside the electrical panel and disconnected it for safety.
New owner said he had it working in October, but it wouldn't start now in March. Thought the spark wasn't working or weak so was in the process of troubleshooting, but not having much luck and was going to take the ad off Kijiji. Was willing to part with it "as is" for $125 Cdn.
He had bought a couple new autolite(?) spark plugs (not installed) and had a primary wire off the coil starting to troubleshoot. Looks like it will take a bit of going over.
Looks like a cover plate missing on the back of the points.
So - manuals, etc: looks like 927-0300 might be a manual number, but there is an awful pile of variations on that theme.
No serial number or spec plate visible
The engine block number looks like 569483. Please could someone suggest which are the right manuals and spec number for this set?
This will be a project to get this back up and running and cleaned up, so likely down the road a few months.
Thanks in advance,
David M
ID:	279618   Click image for larger version
ID:	279619   Click image for larger version
Old 04-08-2017, 10:56:30 PM
yellowlister yellowlister is online now
Email NOT Working
Looks like a 5 kw from the generator stack length.. here is a picture of my 5 kw contractors cck for comparison.
Great score!
The Following 3 Users Say Thank You to yellowlister For This Post:
Old 04-08-2017, 10:58:00 PM
Email NOT Working
Point's cover is gone.. Looks like the condenser is not hooked up
The Following User Says Thank You to yellowlister For This Post:
Old 04-08-2017, 10:59:18 PM
It came with this control panel mounted on the wall.
On the left hand side is in the input plug. It includes the twistlock plugs from the genset to the control panel and then from the control panel to the house junction boxes.
Any comments on using these connectors? - They appear in decent shape, but I don't think I want them because they aren't compatible with anything else I have and I'm not sure they are even obtainable now - should I be perhaps parting them out to restorers and rebuilding the set and panel with current jacks and plugs.
(I think I'm going to go with l14-30 twistlocks as a semi standard - I know this is only 5kw and the plugs are rated 7.2 kw, but they should work safely.)
On the right hand side is the output jack and various control ports
So - wonder which manual this one is? Don't see anything called a switchboard.
Did find this thread
https://www.smokstak.com/forum/showthread.php?t=152185
and grabbed those files to compare although it's not the same model number.
Thanks,
David M
ID:	279621   Click image for larger version
ID:	279622   Click image for larger version
ID:	279623   Click image for larger version
Old 04-08-2017, 11:16:57 PM
Vanman Vanman is offline
Love the generator set, what a great find.
But I *really* LOVE that panel!! That's the REAL score here!
Are the current connectors three or four pole?
Keith
The Following 3 Users Say Thank You to Vanman For This Post:
Old 04-08-2017, 11:32:37 PM
They are three pole connectors, but the shell appears to function as the fourth pole for ground bonding. So 120/240vac with neutral and ground.
Old 04-09-2017, 12:00:06 AM
Email NOT Working
looks like it has some kind of idle control rigged up to the governor... some funky stuff on that.. never seen a older one with a electric starter like that
Old 04-09-2017, 07:14:20 AM
Kevin K Kevin K is offline
Try the older CCK manuals:
927-0300
927-0500
927-0006
927-0754
and a more modern parts manual:
927-0220 Parts Spec A to U
The Following 3 Users Say Thank You to Kevin K For This Post:
Old 04-09-2017, 08:05:42 AM
MBB MBB is offline
Here is the build sheet for the unit. I located the wiring diagrams close to your unit one might work.
The Following 3 Users Say Thank You to MBB For This Post:
Another Cry For Help - Saint Louis Steam Engine Jim Alexander Steam Stationary Engines, Traction Engines, Steam Boats 3 02-22-2017 07:22:53 PM
Saint Mary's Gearless Larry K Antique Gas Engine Discussion 1 01-19-2013 12:21:50 AM
07-21-2012 Saint Marys Mike Monnier Antique Gas Engine Discussion 0 07-24-2012 08:53:26 PM
