Onan Generators Restoring, operating and maintaining vintage Onan generators. |
Onan P248 Diesel Generatorthis thread has 6 replies and has been viewed 369 times
I can't find much info on this Generator. Does anyone know where I can get a manual. This came with a 1960 ice cream truck I am restoring. Any help is greatly appreciated.
OK I mucked up ..I'm low tech and going blind..Onan P2435..I'm sorry |
Sponsored Links |
That is an Onan 12Kw DJC, or DJF Air Cooled.... If you look close near the Oil Filter, you will find a Serial Number Stamped into the Block, on a Machined Flat Surface.... Post that and we can give you the Onan Build Sheet for your specific Genset...
Bruce in alaska ![]() ![]() ![]() |
The Following 5 Users Say Thank You to BTPost For This Post:
And that generator is not from 1960, unfortunately. That would be, what post 1973 or 4? With the electronic AVR on top?
The Following 3 Users Say Thank You to Vanman For This Post:
BT are you talking about the 349846 that is in the second pic..thanks for replying
Van..it came in a 1960 truck i bought. I am sure it isn't original..thanks for replying |
Yes that is the numbers we need. It has the YD back end which came out around 1974.
I don't talk to myself. This early in the morning. Why the hell should I talk to you. |
12.0 DJC-18R/16786AA. It left the factory 10-78.
The Following 6 Users Say Thank You to OnanParts For This Post:
Manuals here http://www.twinslan.net/~n0nas/manuals/onan/
Looks like 967-0108, 967-0222, 967-0301 will get you started , there may be others with good info too. Cheers Dan
It's always something simple. One test is worth a thousand guesses. If some is good and more is better then too much is just enough |
The Following 2 Users Say Thank You to BigBlockChev For This Post:
Thread Tools | |
Display Modes | |
Thread | Thread Starter | F o r u m | Replies | Last Post |
Onan DRP diesel generator | Jeff Conner | Onan Generators | 17 | 07-22-2017 06:08:23 PM |
Onan Diesel Generator | biged55 | Onan Generators | 12 | 02-12-2016 02:25:54 PM |
Onan DJC Diesel Generator | jd318 | Onan Generators | 0 | 02-03-2006 12:22:31 AM |
Onan Diesel Generator | Jeff Conner | Onan Generators | 4 | 02-04-2003 05:59:46 PM |
Onan diesel generator | Max Koone | Onan Generators | 1 | 09-21-2002 06:32:02 PM |
