Onan 4b
this thread has 5 replies and has been viewed 310 times
Old 04-10-2017, 11:32:24 PM
jakemiller09 jakemiller09 is offline
Default Onan 4b
Hello everyone, I have an onan generator in my motor home and I'm having issues with the fuel pump voltage. When cranking wire R7-2 is only getting 8.9v I can make the pump turn on with an alternative 12v source. What could be causing this issue?
Old 04-10-2017, 11:38:58 PM
BigBlockChev's Avatar
Default Re: Onan 4b
Please post the full model and serial# for your generator so we know what you have and can provide appropriate advice. Someone will be along shortly to help. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 04-11-2017, 12:04:34 AM
Default Re: Onan 4b
Serial # f880131937
Model # 4bgefa26100f
Old 04-11-2017, 11:07:32 AM
len k len k is online now
Default Re: Onan 4b
I assume R7-2 is the wire on pump side of the resistor. Bad wire connection maybe??
Check if voltage rises to 12V during cranking, if not maybe diode cr9 is blown. Better yet see if both sides of cr9 are connected to anything, maybe wire got pulled off.
Old 04-11-2017, 11:46:09 AM
Default Re: Onan 4b
I checked voltage going into that ceramic resistor deal and it's 8.9v followed the wire back and it goes to the main switch board
Old 04-11-2017, 11:52:50 AM
Default Re: Onan 4b
Cranking engine draws lot of amps from bat, if bat is weak it's voltage might be dropping to ~9V.
While cranking, Check voltage across bat and also across input to control board.
If that's good check voltage across spark coil while cranking
