Onan 4.0 BFA troubleshoot advice?
this thread has 7 replies and has been viewed 385 times
Old 04-11-2017, 10:43:15 AM
thoml thoml is offline
Default Onan 4.0 BFA troubleshoot advice?
Have a 1986 Onan 4.0 BFA 1R/16020C #F863117686E genset. Past years, always start/run.
Tried firing it up this year, got clicking solenoid sound, so checked battery and cleaned connections.
Still just clicking. I replaced the K-1 solenoid, now when I connect the + battery cable to the solenoid, it slowly clicks constantly, immediately after hooking it up, without engaging the start
switch at all.
Was hoping someone might recognize what this might be, I appreciate any insights.
Old 04-11-2017, 10:53:52 AM
JohnnyC JohnnyC is offline
Default Re: Onan 4.0 BFA troubleshoot advice?
Me thinks bad solenoid. This assumes all electrical connections are clean and secure including a good ground.
JohnnyC
New Jersey
Old 04-11-2017, 11:05:51 AM
nothingbutdarts nothingbutdarts is online now
Where did you buy the K-1 solenoid??? There are a lot of different type of solenoids out there.
Old 04-11-2017, 11:22:08 AM
Vanman Vanman is offline
What is the terminal voltage of the battery while it's trying to crank?
Old 04-11-2017, 11:28:56 AM
I just bought a generic solenoid - Carquest BWD S63P - sounds like that was a mistake.... since it looked the same with same "s" and 'i" primary terminals as the Onan 307-1617 I assumed it compatible.
Old 04-11-2017, 01:06:55 PM
I just bought a generic solenoid - Carquest BWD S63P since it looked the same with same S and I primary terminals as the Onan 307-1617, I assumed it compatible.
Old 04-11-2017, 01:09:26 PM
Billy J Shafer's Avatar
Wrong solenoid.
Old 04-11-2017, 11:42:01 PM
lokay5's Avatar
lokay5 lokay5 is offline
switch at all.
This info may help you-
https://www.smokstak.com/forum/showt...noid+size+fits
1973 CK5 Blazer
The Following User Says Thank You to lokay5 For This Post:
Onan Marine 6.5 MCCK Spec J- Trying to troubleshoot. SpudPlucker Onan Generators 9 08-22-2013 08:10:16 AM
Please help me troubleshoot an Onan engine 69zfarmer Onan Generators 13 11-28-2011 08:38:37 AM
Lincoln SA 200 troubleshoot help? 123weld Welding Shop 1 07-10-2008 07:20:57 AM
won't run right...troubleshoot Jeb Lloyd Antique Engine Archives 6 05-27-2004 12:00:54 PM
Kohler Troubleshoot Smoke Antique Engine Archives 2 06-04-2003 07:32:14 AM
