Onan MDKD 6.5 overheaded and shut down
this thread has 11 replies and has been viewed 820 times
Old 04-12-2017, 02:23:16 AM
Yobbo Yobbo is offline
Default Onan MDKD 6.5 overheaded and shut down
Hello, just wondering if there is anyone who could help with some Onan advise
I have a 6.5 MDKD-P (I'm located in Australia) in my boat, the other night it overheated and shut down, I pulled up the floor to the engine room and could smell a burning rubber smell and a small amount of coolant on the engine room floor. I waited about 1 hour pressed the reset switch and it started up straight away but with a loud squeeling sound like the belt was slipping, I also checked that it was pumping water out of the exhaust which told me the raw water side is fine ( I also checked the raw water impeller just to be sure). The next morning it started up and ran fine but I could hear what sounded like a bearing noise coming from either the cooling pump or the alternator on the actual engine. so here are my questions
Q What engine does my MDKD use?
Is it a Kubota D950?
If it is a Kubota D950 engine does it use any special Onan circulation / water pump and alternator? or just the standard Kubota one?
Thank you very much, cheers Ian
Old 04-12-2017, 04:06:24 AM
Default Re: Onan MDKD 6.5 overheaded and shut down
The serial number is E890240974 , cheers Ian
Old 04-12-2017, 06:04:43 AM
RETCPO RETCPO is offline
Down load your manuals from http://www.twinslan.net/~n0nas/manuals/onan/
981-0502
981-0600
The Following 3 Users Say Thank You to RETCPO For This Post:
Old 04-12-2017, 03:44:23 PM
BigBlockChev's Avatar
I would pull the belt off and see whether it is the water pump or the alternator. I have seen both screw up. I dont believe it is anything special for either one just regular Kubota parts. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following 2 Users Say Thank You to BigBlockChev For This Post:
Old 04-12-2017, 06:50:59 PM
TLB01 TLB01 is offline
Probably the water pump. D650-D950 are the same pump. If it was the little dynamo the machine would have overheated only after the belt snapped and you would have smelled that long before then. Might also want to see if anything blocked the circulation water in the heat exchanger. Gunk or whatever. The MDKC I am working on was pretty disgusting in all the coolant system routing. Doubt it even circulated.
The Following 2 Users Say Thank You to TLB01 For This Post:
Old 04-12-2017, 09:35:06 PM
Thank you for the tips, it's in a sound shield and under the flooring right in front of the starboard engine, it's a real pain to get to it, especially someone my size , how can I tell what model of engine it is? Cheers Ian
Old 04-12-2017, 09:56:00 PM
There should be a CC displacement cast onto the block somewhere. In the case of mine it was below the head, back end of the engine behind the raw water pump. That should get you in the ball park. For example mine is a 675cc engine so its a D650. A D950 has a displacement of 927cc. Otherwise, all those engines look the same. Its like looking at a small block chevy engine and having to guess (if you could not see the balancers anyway). All those SETS look the same. There is a parts set near by that is a 8.0 and looks just like my 4.0. Other than finding the model/serial plate, its hard to tell them apart. Good thing the water pump and the dynamo should be universal for all MDKs. On the land based sets, there are totally different set ups, even if using the same engines.
The Following User Says Thank You to TLB01 For This Post:
Old 06-16-2017, 07:37:17 PM
UPDATE: a big thank you to you all.
I was able to find the model number and it is a D950 Kubota engine. It would appear the wrong sized belt had been installed by the PO and it had started to slip, I replaced the belt with a Gates 7355 (10A0900) and the water pump with a Kubota water pump and also replaced the thermostat (and had the raw water pump rebuilt as preventative maintenance, replaced all oils and coolant with a 50/50 glycol mix) I have now used the genset for around 10 hours and all is working well.
Interestingly when I contacted a local Onan service agent, he told me most people just replace the genset with a new one when the get that old
Thanks again everyone
The Following 3 Users Say Thank You to Yobbo For This Post:
Old 06-16-2017, 08:59:56 PM
Motorhead's Avatar
Something to know that the dealers "Down Under" tell customers the SAME CRAP as they do here! They don't want you to repair them, all they want to do is sell you a new one!
What is worse is that the older models are better built than the newer ones. Too many electronics on the new ones. Good to know you found the problem and that the protection controls on your older set worked well and saved the set from being ruined.
The Control panel
and gauges of my
7.5JB
Old 06-16-2017, 10:16:01 PM
Billy J Shafer's Avatar
Ask him why Onans made in the thirties are still working. That was one reason I was fired by Cummins/Onan. I would rather fix things than sell new.
Onan MDKD Repairs Viking66 Onan Generators 41 01-08-2018 05:31:50 PM
ONAN MDKD-1R 1B Manual mainship Onan Generators 8 12-16-2017 11:42:15 AM
Onan MDKD 7.5 TLB01 Onan Generators 12 03-16-2017 05:48:23 PM
Onan 8 MDKD Straitsman Onan Generators 9 04-22-2015 03:12:20 PM
Help! Can't start Onan 8k MDKD jeffgregory Onan Generators 10 09-17-2006 09:09:26 AM
