Onan 4.0kW Generator has been sitting for at least 6 years
this thread has 32 replies and has been viewed 1421 times
Old 04-15-2017, 03:50:27 PM
len k len k is offline
Default Re: Onan 4.0kW generator has been sitting for atleast 6 years
I've used my fork method under slip rings several times on my NHM, it's pretty much identical to BGE design. The curve of fork tines fits slip rings very well. When placed under slip rings, the rings rotate away from you, so seems no risk of getting caught. Just don't let go. At that small diameter the surface velocities seem minimal to me, but I'm a ME and everyone has to make that judgment call for themselves
I however have did this with AC voltage reg unplugged so there is no voltage in genhead. Well actually real reason reg was unplugged is because it's still in cellar still waiting for me to remove more of it's potting and repair it.
Old 04-16-2017, 12:14:01 PM
twitchee2 twitchee2 is offline
Default Re: Onan 4.0kW Generator has been sitting for at least 6 years
Thanks for all the suggestions guys. I didn't get a chance to really play with it yesterday and doesn't look like I will be getting a chance until tomorrow or the next day. I did look to see and I think I will need to completely drop it out of the RV.
Anyway, here is the full model number and spec
Also, here is the signal to the Fuel pump. It looks like some sort of PWM signal that is ~60V, that doesn't seem correct does it?
Old 04-16-2017, 12:24:05 PM
The control board won't make PWM , it's just simple relays and maybe a series diode. The PWM pattern has to be coming from either inductive kick back from the solinoid in the gas pump or from inductive kickback from the spark coil. Try unplugging the pump ( at the pump) and see if PWM pattern is still there.
Can't read the voltage scale on the voltage/time graph. What's the voltage at the bottom of the spikes? I'm guessing it's bat voltage ~ 13VDC. Right??
Also what's the voltage at the peaks of the spikes?
Your gen is spec C (version number).
Manual numbers and link to them:
BGE-BGEL spec a-c SERVICE--(5-89)--- 965-0530.pdf <---------------------read this one
BGE (A-E)---BGEL (B-D) --PARTS---965-0232 Emerald I.pdf
BGE-BGEL--INSTALL---965-0630.pdf
BGE-BGEL OPERATOR---965-0130.pdf
http://www.twinslan.net/~n0nas/manuals/onan/
The Following 2 Users Say Thank You to len k For This Post:
Old 04-16-2017, 12:43:15 PM
I bet you are the first one to hook an expensive 'scope to the fuel pump power lead. So no frame of reference to know if what you see is a normal by-product of how the set works...
The Following User Says Thank You to pegasuspinto For This Post:
Old 04-16-2017, 01:04:37 PM
Never know what's there till you look at it.
The old simple relay logic and points didn't care about spikes , no electronic to kill.
Kickback is likely why newer model gens (NHM) have a zener diode from +12V spark coil lead to ground.
And a freewheeling diode across relay that powers the Onan 7NHM pump.
NHM is very similar to BGE, but control board is design a bit differently.
Interestingly on Chevys I see freewheeling diodes across motors and solinoids to stop the inductive kick. Seen them on A/C electro cluch on pump, relays and other places..... helps protect the computer from damaging spikes.
Old 04-16-2017, 08:06:55 PM
The bottom of the those spikes is ~10V which makes sense. the scale is 20V/div so spike to about 100V. Time scale is 200ms/div so I bet those spikes are is noise from each spark. That first picture is at the fuel pump power lead with the pump disconnected.
This picture below is with the Pump connected. it is sitting very close to 10V which is more normal. I think it is safe to say the PCB is working properly.
That you for all of those manuals! I have some reading to do and likely some cleaning to do on the slip rings, etc.
Old 04-17-2017, 12:13:35 AM
I haven't had a chance to take check the brushes and clean the slip rings yet. Assuming those get cleaned and brushes are all good. What do I need to check next. I would assume clean the carb, but am I missing anything else?
Thanks for all your help so far!
Old 04-17-2017, 12:38:28 AM
Motorhead's Avatar
Pull the points cover and clean and check the point gap. Any idea of the total hours on the generator? If it has 1000 hrs or more, I would suggest you adjust the valves. If the oil in the set has sludge at the bottom of the oil pan then I would change the oil and filter, run the set with a good load for an hour or so then change the oil and filter again and put your favorite "flavor" of engine oil and a GOOD oil filter. I run Rotella T6 full synthetic, 5/40 diesel rated oil. It still has the good stuff in it for flat tappet cams and it sticks to parts well.
I feel the 4BGE and that series of small sets were some of the last decent sets made by Onan before they went to the 3600 RPM, 1 quart oil capacity, no oil filter sets. My $0.02 worth.
The Control panel
and gauges of my
7.5JB
Old 04-17-2017, 01:10:23 AM
Already have some T6 to put in there with the extended filter. Per the hour meter its got 132hrs. Good call on the points.
Thanks!
Old 04-20-2017, 12:48:09 AM
Cleaned the Slip rings, they certainly needed to be cleaned up a bit. All good there. Tried to fire it up and nothing. It would run on starting fluid. Doubled checked the fuel pump and it is pumping just fine!
Pulled the carb off and Huston we have a problem! Nothing in the carb moved freely, it was so gummed up and nasty. Got it all nice and clean, just need to get a couple of O-rings and think she's going to be running just fine!
I will update in a couple of days!
Real quick, once I get it fired up how do I check the voltages and frequency? Are there any regulators I need to worry about?
Onan 4.0BF-3CR/16000B RV Generator Startup After Sitting for 6 Years farmer52 Onan Generators 26 10-21-2015 11:50:52 AM
1911 FBM 4 hp T after sitting many years Mark S Frank Antique Gas Engine Discussion 5 11-22-2013 10:26:20 PM
Onan 20ES Starting after Sitting for 10 years Curtis 916 Onan Generators 15 11-23-2012 02:44:36 AM
onan engine sitting for years lafhouse Onan Generators 14 09-09-2011 07:50:47 AM
Sitting 50+ years the Gilson runs Brian.P Antique Gas Engine Discussion 17 02-10-2008 07:51:29 AM
