Are the MEP 002 genends the same as a JB YD genend
this thread has 4 replies and has been viewed 304 times
Old 04-15-2017, 08:13:11 PM
BigBlockChev's Avatar
Default Are the MEP 002 genends the same as a JB YD genend
There is one for sale locally with a dead gen end but I have no experience with them. I do have several JB gen ends though. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 04-15-2017, 08:16:12 PM
Default Re: Are the MEP 002 genends the same as a JB YD genend
Not even close.
Old 04-15-2017, 08:39:39 PM
TLB01 TLB01 is offline
Its something totally different. Whole set is 24volt operation and its all EMP proof. Oil pan is different. Intake manifold is different. Exhaust is different. Its still a DJE type engine though at its heart only all the glow plugs are 24 volt. Control board is something different. If you see YD control boards for sale with a NSN, they came off aircraft auxiliary engines which are normal Onan sets with OD green on them. Then again they are made to just hang out at an airfield and not be outside the wire.
Might be able to retrofit it all to 12volt and put a Stamford end on it or something of that nature. You also could just flush your money down a toilet or Paypal it to me. You would get about as much ROI.
Those milspec sets seem best bought in pairs or more. If you want to fix a MEPsomething, its best to just buy another one and have a carcass to cannibalize.
Old 04-15-2017, 08:50:32 PM
Ok lesson learned. Cheers Dan
Old 04-15-2017, 09:34:45 PM
David C David C is offline
There are a lot of differences between the MEP and the civilian DJ's as others have stated. The one that jumps out at me is the MEP has the ring gear, starter and flywheel on the generator end of the engine. It uses a flex plate to drive the armature instead to the direct taper mount to the crankshaft.
David C.
MEP-005 50/60 and 400Hz on the Same Genend? krc002 Military MEP and Aircraft Gen-Sets 8 02-17-2012 12:28:52 AM
Oil and I.D. of Genend badattitude1957 Military MEP and Aircraft Gen-Sets 16 12-26-2010 05:29:59 PM
Help locating Used single bearing Genends pilot199 Generators & Electric Motors General Discussion 5 11-25-2010 01:20:02 PM
Flashing a 12.5 genend krc002 Onan Generators 3 12-04-2009 04:12:45 PM
Home Backup: which genend? wyM1Aguy Onan Generators 5 10-07-2009 12:38:14 PM
