Easter Score... Kohler and 2 Onans...
this thread has 23 replies and has been viewed 1183 times
Old 04-17-2017, 01:12:21 AM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Re: Easter score.. kohler and 2 onans..
Originally Posted by JohnnyC View Post
Congrats (again). I see a JC in the pictures. Not a welder or a 3600 rpm generator. Did you attach the correct pictures?
I think by the end of the year you will have almost every antique generator in your state safely stored in your garage(s).
JohnnyC
New Jersey
The welder/generator is a Miller AEAD 200LE. 200-225 Amps AC/DC with 5KW of 120/240 AC on the generator side...at...1800 RPM.
The Following 2 Users Say Thank You to OnanParts For This Post:
Old 04-17-2017, 02:00:00 AM
yellowlister yellowlister is offline
Email NOT Working
Default Re: Easter Score... Kohler and 2 Onans...
Story with the welder is the last owner tuned it up and could not get any spark.. im going to clean it up remove the aftermarket propain adapter and put it all back together stock and sell it as is.. absolutely no interest in it as I have a Miller d400 diesel on a service truck that's retired
Old 04-17-2017, 12:19:06 PM
Mac Sine Mac Sine is offline
An interesting lot of gensets. I am curious about the Tecumseh-powered one. I am wondering what that reservoir-like container is near the gas regulator and also the purpose of the extended box around the muffler. I can understand that the box could be a type of heat shield but I noticed it extends around the top front of the engine.
Regarding those Beam gas regulators on the Tecumseh and on the welder, Beam is now part of Impco, so if they need a rebuild kit, an Impco dealer should be able to help you.
The Following User Says Thank You to Mac Sine For This Post:
Old 04-17-2017, 12:36:07 PM
Email NOT Working
It's a oil resevor.. not sure how it works has some kind of pump on the engine.. no idea on the box... yet
ID:	280243   Click image for larger version
ID:	280244   Click image for larger version
Old 04-17-2017, 09:29:10 PM
Motorhead's Avatar
It needs an oil reservoir because it is a Tecumseh!
The Control panel
and gauges of my
7.5JB
Old 04-17-2017, 10:01:33 PM
Email NOT Working
Of course there is a mouse nest in the control box
Old 04-18-2017, 05:22:56 AM
Handyhiker1 Handyhiker1 is offline
At least it is a small nest. :-(
Old 04-18-2017, 05:48:23 PM
Email NOT Working
Fresh water in number 1 and 2 cylinders..
Who needs parts?? Feet and exhaust are already spoken for everything else is up for grabs..
Natural gas and propain carb.. starter, high compression heads? Not sure how to tell... 12 wire generator and magnaciter
ID:	280360   Click image for larger version
ID:	280361   Click image for larger version
ID:	280362   Click image for larger version
Old 04-18-2017, 06:40:04 PM
grif grif is offline
The side door (access to the carb and oil filter side). Any chance that's going to be the same as mine from the 80's?
Wonder how much it would cost to ship?
Old 04-18-2017, 06:47:20 PM
Email NOT Working
There the same.. shipping I have no idea..
This is actually a 10 wire generator end.. anyone seen that before?
Kohler 4.5 ckm 21 score yellowlister Kohler Generators 9 12-19-2016 02:12:27 AM
Kohler 30 RH 62 Score yellowlister Kohler Generators 6 06-14-2016 09:59:04 PM
Kohler 12.5 CCO diesel score yellowlister Kohler Generators 12 03-08-2016 08:03:46 PM
kohler 4cm21 score for 100 bucks yellowlister Kohler Generators 11 01-24-2016 04:49:50 AM
