Onan 20 ES - Switch from Natural Gas to Propane
this thread has 19 replies and has been viewed 726 times
Old 04-18-2017, 05:49:26 AM
tek42879 tek42879 is offline
Default Onan 20 ES - Switch from Natural Gas to Propane
Hi guys,
I'm new here and new to generators in general. Over the weekend I acquired an Onan generator. I got it home and got it unloaded so I would be able to tinker with it in my spare time. I put it battery in it and it started cranking.
Unfortunately for me, this generator was hooked up to Natural Gas and that utility isn't available in my area. I would like to be able to convert it to propane, but I have no idea how to do this. I'm a CNC machinery guy so this thing is way outta my league.
The good news (I think) is that it only has 200 hours on it and the oil is clean.
I have attached some photos of the generator - serial and model # included. I have located the user manual with the help of the sticky posts on here, but I don't see anything in it in regards to switching from natural to propane.
Also, would it be safe to use a pressure washer on the engine and the generator? It has a layer of wood dust stuck to it everywhere.
ID:	280318   Click image for larger version
ID:	280319   Click image for larger version
ID:	280320   Click image for larger version
Old 04-18-2017, 05:53:00 AM
Default Re: Onan 20 ES - Switch from Natural Gas to Propane
More photos
ID:	280322   Click image for larger version
ID:	280323   Click image for larger version
Old 04-18-2017, 07:03:40 AM
GMGuy GMGuy is offline
Just my 2 cents, and I am sure the experts will chime in, but I would stay away from a pressure washer (electricity and water are not a good mix), and perhaps use compressed air to blow it off and clean it out.
It looks like a great set.
The Following 2 Users Say Thank You to GMGuy For This Post:
Old 04-18-2017, 07:11:43 AM
Within reason, yes you can pressure wash the engine end. I would keep the water away from the gen-end and control box. Lots of air will likely disperse he dust from the electrical areas.
Nat gas to propane; remove the primary regulator (the aluminum one, not painted green). Remove the spring and turn the next one 180 so it is pointing down. I will attach a document provided us by Billy that explains this process. Beyond that a little tweaking of the mixer adjustments should be all you need.
Download a copy of the T-015 gaseous fuels manual from the twainslan site http://www.twinslan.net/~n0nas/manuals/onan/ you will also find the generator service manual at this site.
I wonder why the 20 ES single phase set is only rated at 18 KW????
File Type: pdf LP converson of pressure regulator.pdf (139.3 KB, 38 views)
The Following 5 Users Say Thank You to Max Thompson For This Post:
Old 04-18-2017, 07:15:51 AM
The smart guys will be along any minute to help you. But #1 is to replace the timing belt that is who knows how old. The good part it's cheap as it's a Ford engine such as used in a lot of cars in the 70's to early 90's. An auto parts store should have the belt and idler for you.
Old 04-18-2017, 08:16:03 AM
Jim McIntyre's Avatar
Derated for natural gas ?
Old 04-18-2017, 09:03:02 AM
Billy J Shafer's Avatar
I agree I would change the built now. You can wash the engine but stay away from the control box. Use air to blow out the control box. I would use a water hose to rinse off the engine. Not a pressure washer unless it is a low pressure one.
Old 04-18-2017, 09:23:51 AM
grif grif is offline
Billy,,, does this have the mechanical governor that to tight belt will damage?
Lots of threads on the Ford 6's, lots of docs floating around. I chased this info looking at a 30EK
http://www.pittauto.com/default.aspx...es/pl_ford.htm
http://engineguy.com/ford-lincoln-me...300-cui-1.html
I think all of the ford engine stuff has ended up on Twinlan, if you can't find the manual you need, but know the onan part number of that manual, there are several of us that can get it to you.
Did you post the whole model/serial number yet?
Old 04-18-2017, 09:31:51 AM
Model and serial are in the photo, but here they are for copying and pasting if needed.
Model No. 20.0ES-3R/9132B
Serial No. G860829753
Thanks Max, I will do this one day this week.
Once this is done, how to I hook the propane up to it? I assume there is a special fitting that I will need? The natural gas line looks to be much larger than propane lines that I am used to seeing.
Old 04-18-2017, 10:08:41 AM
Look at the first picture in post 2. The round item just in front of the carb. Two wires going to it. Is the electronic gov. Controller for it is in the main control box. Don't recall the ES coming with a mechanical gov.
Garretson impco regulator set for propane want to switch to natural gas Geabrod Generac Generators (SEARS, etc.) 5 12-02-2015 05:54:23 PM
Onan 6.5NHL Propane to Natural Gas timjea Onan Generators 12 01-26-2014 08:22:16 AM
Onan CCK gasoline to propane/natural gas conversion threejeeps Onan Generators 5 10-05-2012 05:01:30 AM
Onan 30.0 EK. don't know if its natural gas or propane Pete Spaco Onan Generators 2 05-21-2011 05:40:20 AM
Onan 30 oak-15r Manual Propane or Natural Gas Jpoineau Onan Generators 3 04-24-2011 06:33:03 AM
