Found an Onan AK today
this thread has 24 replies and has been viewed 1595 times
Old 04-19-2017, 07:03:08 PM
MadMachinist MadMachinist is offline
Default Found an Onan AK today
I came across this little gem in a barn today. It's in perfect condition. Paint looks like new. Gas tank smelled like varnish so we drizzled a little fresh gas in the carb and with a couple pulls it fired and run just enough to make the bulb on the end glow a bit.
It's one heavy little gen set.
Can anyone tell me the build date?
What's it worth?
Old 04-19-2017, 07:09:50 PM
Billy J Shafer's Avatar
Default Re: Found an Onan AK today
Made in Sept 1963. probably worth 100-200 dollars.
Old 04-19-2017, 07:43:10 PM
We need more pictures...
Old 04-19-2017, 07:53:45 PM
I offered $200 for it so I might be able to get as many as you want if he takes it.
Seriously, it looks almost new. I knew it was old and was shocked at its condition.
A friend of mine bought a warehouse full of fire department stuff. It was on a skid with some other old Winco sets. The muffler still has most of the paint on it.
Old 04-20-2017, 09:07:09 AM
Ray Lynch Ray Lynch is online now
Definitely more pics if you get it.
3600 RPM set.
Ray
Old 04-26-2017, 10:26:04 PM
He delivered it to me this afternoon. Would only take $100 for it because it won't stay running. If we put a dash of gasoline down the intake it will fire and make power but as soon as that's gone, it dies.
Is that a fuel pump below the carburetor? It appears to have a primer lever on the side. The lever has what I think is the remains of a spring. It stays in whichever position I move it to.
I'm certain the problem is fuel. Either the float is stuck closed or the pump (if that's a pump) isn't working.
The petcock on sediment bowl is open.
What's the best place to start Billy?
ID:	280952   Click image for larger version
ID:	280953   Click image for larger version
The Following User Says Thank You to MadMachinist For This Post:
Old 04-26-2017, 10:31:13 PM
Wow that is a clean onan! I would remove fuel lines at the pump and squirt some wd 40 in and see if the diaphram losesns up.. there are diaprhram rebuild kits online for 20 bucks.. after sitting so long it could be dried out
May be time for a oil change after 7 years
Old 04-26-2017, 10:38:27 PM
I fell in love with it when I seen it.
Sorta like a little puppy sitting alone in a corner.
I'm going to get it running and maybe use it here or there. I have a 15.0 JC on wheels if I need serious power.
Old 04-26-2017, 10:46:05 PM
I would start with the pump. I have a cck in the shop for service. 1978 model hasn't run it ten years. Put some oil in the pump let it set for an hour. Spun it over started just fine. If the pump is working. You may need to clean out the carb.
The Following 3 Users Say Thank You to Billy J Shafer For This Post:
Old 04-27-2017, 12:14:57 PM
Very nice - Sweeeet I don't even think twice about it - pumps like this get rebuilt/replaced (mechanical/electrical/vacuum style), gravity-fed, or converted to propane. If age didn't get it, the ethanol will. Even if it's just stuck or dirty now and you get it working, it probably won't last. Diaphragm gets stretched and might even work, but fuel still permeates through it. Smell the oil.. The nose knows
The Following User Says Thank You to gnucklehead For This Post:
Found these today! Dusty Antique Gas Engine Discussion 13 04-24-2013 04:12:25 PM
I found another IHC L today oldironlindy Antique Gas Engine Discussion 11 05-31-2011 07:52:05 AM
Yet another F20 found today HBurk Antique Farm Tractors 16 04-02-2010 10:42:53 PM
F20 found today HBurk Antique Farm Tractors 29 01-27-2010 01:11:45 AM
What we found today eric hawkins Antique Gas Engine Discussion 3 03-30-2008 09:56:18 PM
