Onan Parting Out Thread (Used Onan Parts only!)
this thread has 498 replies and has been viewed 35753 times
Old 04-09-2017, 10:43:47 PM
JohnnyC JohnnyC is offline
Default Re: Onan Parting Out Thread (Used Onan Parts only!)
Originally Posted by LRomero View Post
It's for sale, just haven't seen anyone looking for one to post it. PM me an offer if your interested.
I will. I am interested in the entire control box. I like all the OEM Onan bells and whistles. Since I have all those options, it may work out. I just don't know why I don't have all the resets you got and the additional 2 gem lights. Although we have the same options, has the design changed between the two and my design does not use the same resets?
I will PM you in about 2 weeks. Since day-one of my refurb, the control box was removed from my JB put high up on the shelf and I did not look inside the box other than check for mousy nests. Also, I want to go over any wiring diagrams for my control box.
If you have time, can you snap a couple clear and closeup pictures showing the wiring and components inside the control box?
Thanks,
JohnnyC
New Jersey
Old 04-09-2017, 10:49:49 PM
LRomero LRomero is offline
Thanks,
JohnnyC
New Jersey
Sure thing. I'll get some pictures tomorrow.
The Following User Says Thank You to LRomero For This Post:
  #303
Old 04-10-2017, 09:07:25 PM
Pictures for JohnnyC. Kind of tough to get a good picture with the wires. If there is something specific you want to see, let me know.
Old 04-10-2017, 10:16:41 PM
Wow! The inside of your control box is much different than mine and a cleaner layout too. I need to go back into my workshop and take a peek inside my control box. When I took pictures the other day, I did not remove it from the shelf.
I don't need the voltage regulator. Some of the components inside the control box are hard to find and pricy. Anyone that have extensive mouse damage from pee would grab that relay in a heart beat. I am surprised no one asked about your tri-fuel carburetor.
I will get back to you either tomorrow or Wednesday.
Thanks!
JohnnyC
New Jersey
Old 04-10-2017, 10:40:33 PM
I could not wait until tomorrow and was able to find a picture of the inside of my control box. I got your control box picture side by side with mine as seen below.
JohnnyC
New Jersey
Old 04-11-2017, 10:48:41 AM
JC Exhaust manifold available. Make me an offer and shipping from 70506.
Old 04-11-2017, 10:57:04 AM
JSConan JSConan is offline
I am looking for a 231-0161 generator adapter, the housing between the generator and engine , for a JB or JC to YD gen. Also a 234-0493 air outlet cover assembly for the adapter, it's the louvered cover over the charge resistor.
Old 04-11-2017, 11:15:28 AM
I have a complete 15kw YD generator end off a JC that has 231-0161. They are separated now and I'd rather keep together, but would consider selling separate. Make me an offer and I also have the air outlet cover for it.
Old 04-11-2017, 11:36:39 AM
PM sent, Thank You
Old 04-11-2017, 11:46:41 AM
BigBlockChev's Avatar
I have just that adaptor as well . Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
Old 04-11-2017, 12:49:25 PM
mheltunen mheltunen is offline
Hey guys, I'm looking for a front access door and a points cover for a 7.5 JB. Thanks
Old 04-12-2017, 11:42:17 AM
Mooncuser Mooncuser is offline
Does anyone out there happen to have a transfer solenoid motor # 306-3623-02 and a rectifier # 305-0653 for sale any leads would be helpful
Thank you
Old 04-19-2017, 10:01:54 PM
PnishrPW PnishrPW is offline
Pulled this complete raw water pump off of my MDJE, it's never going back on. Bearings seem good, impeller is intact - I believe it's a good builder. Pickup (preferred) or postage takes it!
ID:	280464   Click image for larger version
Old 04-20-2017, 11:50:28 AM
yellowlister yellowlister is offline
Talking Re: Onan Parting Out Thread (Used Onan Parts only!)
I have some cylinder heads from a gaseous jc, starter, gaseous j series carb, cooling tins for pressure cooled jc, complete 10 wire magnaciter generator and.
Rubber feet, cooling door and exhaust are spoken for.
i also have dje djb djc cylinder heads, and djc djb shut off solenoid
Old 04-25-2017, 05:52:27 PM
Jc magnaciter from 120 208 3 phase 12.5 kw.. distributor, coil, air filter, natural gas carburetor cooling tins, I habe the door still.. complete aside from rubber feet and exhaust manifold and centrifugal switch cover
Make an offer on the parts you need.. magnaciter coils look good.. no way to test it but can ohm out coils
ID:	280875   Click image for larger version
ID:	280876   Click image for larger version
ID:	280877   Click image for larger version
Old 04-25-2017, 06:25:09 PM
Motorhead's Avatar
Joe, there was someone a short while ago that was looking for a complete distributor. It was for a 12.5JC. Chris
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
  #317
Old 04-26-2017, 12:55:06 AM
Hi guys, looking for a few pieces for my MDJE project:
YD penthouse upper tin, don't need lid.
J series pre-low oil pressure sensor or specs for same.
R/M DJ series pre-high temp sensor or specs for same.
-1540 unpotted core YD board, just need an intact board to build.
I'm sure there'll be more...
I'll have a clean, functional K12 relay available as soon as I do my cube relay conversion. Pickup (preferred) or postage for anyone one who wants it.
Thx, Dan
Old 05-01-2017, 09:33:54 AM
I have a set of new in wrapper JC head gaskets. I bought them for the 15.0JC, but have started parting it out, so now I no longer need the head gaskets.
Old 05-01-2017, 12:11:06 PM
Radarman Radarman is offline
Not sure if this is still available, but sending a PM now..
Old 05-07-2017, 06:54:08 PM
Jc magnaciter parts anyone???
ID:	281680   Click image for larger version
ID:	281681   Click image for larger version
ID:	281682   Click image for larger version
The Following User Says Thank You to yellowlister For This Post:
Onan 12.0 DJC parts tim berkemeier Onan Generators 3 09-21-2011 09:11:12 PM
Onan parts Karl Onan Generators 1 04-17-2008 10:22:27 AM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
Onan cck parts JDavid Onan Generators 1 03-14-2007 10:17:16 AM
Parting out engines thread Handlebar99 Antique Gas Engine Discussion 19 03-27-2006 09:44:37 PM
