Running Onan Generator from JXQ-10 Chinese Gasifier on Wood Chips, First test
this thread has 1 replies and has been viewed 8019 times
Old 06-26-2011, 05:50:11 PM
Default Running Onan Generator from JXQ-10 Chinese Gasifier on Wood Chips, First test
On Saturday, June 19, 2011, I ran my first test of Using the Chinese JXQ-10 gasifier on wood chips to power my Onan 6.5 NH generator. The fuel was wood chips. I managed to get an electriacal output of about 3.9KW from the generator for about 12 minutes during the test.
I am looking for other owners of the JXQ-10 gasifier to correspond with to share experiences.
The results can be seen at:
http://www.spaco.org/JXQ10A.htm
and I have a 10 minute youtube video of that run at:
http://www.youtube.com/watch?v=nZri_XBdifc
Pete Stanaitis
Old 02-28-2013, 11:25:32 AM
sdowney717 sdowney717 is offline
Default Re: Running Onan Generator from JXQ-10 Chinese Gasifier on Wood Chips, First test
Interesting idea but as you found out not easy for homeowner to do reliably.
Just break down the wood straw leaves fuel with heat pressure and zeolite catalyst into pure gasoline. then everyone can use it in liquid form.
http://www.livescience.com/15310-gre...r-nsf-bts.html
http://orbit.dtu.dk/fedora/objects/o...249326/content
Still we are not running out of oil ever as it is not all fossil fuel. It is mostly abiotic in origin. I have read that all the oil we have drawn out exceeds by a large amount the biology required to have made it. And I have read that coal is oil that carbonized.
A lot of mixing has gone on deep in the earth with sediments and fossils and abiotic oil and heat, pressures, steam, calcium carbonate and iron as a catalyst.
http://www.viewzone.com/abioticoilx.html
Running an engine on wood Kelley Hulsey Fuels and Alternative Fuels 29 06-06-2010 11:09:13 PM
Chinese generator help butchfig8 Generators & Electric Motors General Discussion 8 06-10-2008 12:56:14 AM
Running an engine on wood gas Grape Hit & Miss Gas Engine Discussion 15 05-30-2008 08:09:26 AM
new Chinese ST generator head KeithW Generators & Electric Motors General Discussion 7 07-17-2007 12:12:17 AM
