Chinese generator help
this thread has 8 replies and has been viewed 3797 times
Old 05-24-2008, 08:40:29 AM
butchfig8 butchfig8 is offline
Question Chinese generator help
Have small 1000w, 110v Chinese generator, no name on it.
Has small gas 4 cycle eng, quit working wile running
Is brushless, two blue wires and two black wires come
out of the field wiring. The two black wires are
connected to a bridge rectifing diode,
The two black wires test grounded to the case ??
I do not think the bacl wires should ring grounded to the case.
Can you find me a answer to this
Old 05-24-2008, 01:37:36 PM
Default Re: Chinese generator help
You don't say whether the other (blue) wires are the 110 v output wires or what? I doubt the ones connected to the rectifier bridge are supposed to be connected to ground, but you might want to disconnect them from the rectifier and see if perhaps the problem is in the stator, bridge or the exciter field.
Any chance of a drawing of the layout of the generator wiring?
Old 05-24-2008, 10:01:24 PM
K D Redd K D Redd is offline
Are you sure the diodes are a bridge rectifier OR just two diodes in a package that looks like a bridge. I made this mistake on a generator I worked on last spring which had went down during the Jan. 2007 ice storm. The packsge the diode were in looked like a bridge. I installed a bridge which burnt out. I measure the windings powering the deoide and it was grounded. I intalle another bridge BUT I did not connect rhe negative terminal to anything. In fact I cut it OFF. The generator left the shop with the owner and it generated power. If there is only two diodes in the package the center point of the windings feeding the diodes will be grounded to the case.
Kent
Old 05-25-2008, 09:41:56 AM
Fred M. Fred M. is offline
Butch-
Kent is most likely correct. The Black wires to the rectifier are probably for charging an automobile battery, and may not have any effect on AC power generation unless there is a short circuit.
I think the wires are coming from the stator, not the field, since it is a brushless design. The Blue wires would be the AC output, assuming they are connected to the AC electrical outlet.
The field would be the Rotor winding. It should have one or two diodes mounted on it. A bad diode would cause AC output to fail.
There should also be two more wires connected to a Capacitor. The capacitor may have failed, causing the AC output to fail.
Fred
Old 05-31-2008, 09:54:43 AM
Found a elect diag. looks close. Grounded black wire is the DCWinding in the middle of the page.
Tried gen with Grounded black wire disc. no luck.
12Uf cap test good, is not in the diag. Runs from output side of AC ckt breaker to white wire winding, lowest winding on the page. Cap on correct position ??
Name:	Gen Elect Dia 1000W elec diagram.jpg
Old 05-31-2008, 02:18:12 PM
BTPost's Avatar
BTPost BTPost is offline
Talking Re: Chinese generator help
I don't see ANY connection to the Input of the Exciter Winding (FW) other
than the Block you show a Diode. In order to get power out you have to have
power into the Exciter Winding, from the Diode Block thing, and you show no
other connections to that Block, and unless it has a self-contained Battery
Source, it can't exciter the Genend. The DC Winding (DCW) is the DC Output
source. The AC Output Winding (MW) is the Stator Winding, but your diagram
shows NO Exciter input power source, and without that you are not going
to be generating and power, anywhere.
Bruce in alaska
Old 05-31-2008, 02:32:30 PM
Butch-
What if the diagram is in error? You can see that the left-hand "MW" (Main Winding?) winding, appears to have taps at the top and just below the top, on the side that is jumpered to the frame (neutral). If these taps are actually where the wires for battery charging are connected, that would explain continuity between the black wires and ground.
If the diagram is correct, and there is actually a separate winding for the battery charger circuit, then there could be a short circuit between that winding and the main AC winding, or between that winding and the frame.
Did you disconnect all wires to the bridge rectifier? A shorted diode would be a problem regardless of how it is wired.
If it worked initially, then the capacitor is probably connected to the right place.
Bruce-
I think "FW" is the rotating field winding with its diodes.
Fred
Old 06-09-2008, 11:44:18 PM
russcomp russcomp is offline
did you fix it ???
Old 06-10-2008, 12:56:14 AM
BTPost's Avatar
That could be Fred, BUT that winding needs to get energized from SOMEWHERE, and according to your diagram it isn't connected to ANYTHING,
but the Block with a diode Symbol in it. No Field current, NO OUTPUT. it really
is as simple as that.
Bruce in alaska
new Chinese ST generator head KeithW Generators & Electric Motors General Discussion 7 07-17-2007 12:12:17 AM
chinese parts HBurk Hit & Miss Gas Engine Discussion 10 05-12-2005 08:16:55 PM
