Twin City 27-44 Restoration Started
this thread has 167 replies and has been viewed 42272 times
Old 10-21-2008, 12:32:01 PM
Default Twin City 27-44 Restoration Started
Last year I sold some of my tractors to gather extra cash to purchase this 1928 TC # 250417.
It was a road builder in north-central Minnesota originally and went through three other owners and 40 years sitting without being restored.
I started tearing into it this fall, thought you may like to see the latest mess I have gotten myself into
ID:	41991   Click image for larger version
ID:	41992   Click image for larger version
Old 10-21-2008, 01:17:23 PM
Steve Kunz's Avatar
Steve Kunz Steve Kunz is offline
Default Re: Twin City 27-44 Restoration Started
That should keep you busy this winter. It will be a very nice tractor. What all does it need, was the engine stuck? Keep the pictures coming.
Steve
Old 10-21-2008, 02:52:55 PM
Andrew Yeary's Avatar
Andrew Yeary Andrew Yeary is offline
Looks good Tony. Keep us updated.
The Following User Says Thank You to Andrew Yeary For This Post:
Old 10-21-2008, 04:19:14 PM
Flying Dutchman
Hi,
I restored a 27-44 myself from the bottom, so I can pretty much dream the tractor. If you need any help or pictures please let me know and I can probably help you with it.
Mine was stuck, I made new valves and guides for it, pitty I had to make twice as much as "normal".
Now it is a strong runner though and a nice tractor to drive.
Ours came from Argentina originally, Bahia Blanca is the place where it use to work.
Gijs
Old 10-22-2008, 04:11:56 AM
German George's Avatar
German George German George is offline
Originally Posted by Flying Dutchman View Post
Hi,
Gijs
Yours runs like a bag of nails
and your oil pressure is less than zero
what sort of wheels do you have on it extra small ones?
Road King Wheels the only way to drive a Tea and Cake
Old 10-22-2008, 07:03:08 AM
Hey dutchman up in air,
I sea you and Jeorg have meet one another before.......
Also sea Jeorg cents of humor not lost yet from married life
Gentalmen, I am pleased that you care enough to check in on the Stak and offer help and humor!
Dutchman, I would like to add your tractor serial number and location to my registry! Does your Bahia Blanca export have another brass tag under serial tag showing import information
into Argentina? Could you post a picture of your tractor here?
Thanks guys, maybe some day we can tease each other in person
Old 10-21-2008, 09:53:29 PM
It needs a complete resto, however, the general condition of the tractor is good. I do not believe it was "pulled to death", because the lugs that I removed to facilitate trailering were very tall and sharp, drawbar is real nice, steering and spindles are good. The tractor was stuck at one time. A previous owner got it loose, did a very poor valve job to get it running and found out the clutch is a useless gob of rust, then it was shoved back in the corner for about fifteen more years.
It will take some doing to get the engine back in shape.....crankshaft must be turned, all bearings will need to be poured, cylinders bored and fitted with new pistons and the entire valvetrain is clapped out. It will need a new clutch, sheetmetal and radiator....... More to come as I get time.
Twin City 40 Tom Cwach Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 11-16-2016 03:03:49 PM
Twin City 17-28 Jim Gordon Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 06-07-2008 07:25:42 PM
MM Twin City JTS DavidRaines Antique Farm Tractors 3 05-10-2008 11:02:19 AM
Twin City 17-28 Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 12-28-2007 12:03:49 PM
Twin City Kevin Roth Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 01-13-2005 07:54:14 PM
