Macleod, Sattley and Field Brundage
this thread has 3 replies and has been viewed 1431 times
Old 05-22-2014, 11:07:02 PM
Will Batty's Avatar
Will Batty Will Batty is offline
Images: 33
Default Macleod, Sattley and Field Brundage
Going to drag up a couple of old posts here and bring up some information that I have come up with.
Back in 2007 while I was still living in Whitewood, Sask. a local gentleman brought some pictures of an engine to see if I could help put a name to it. Turns out that with help of this site that the engine was a rather scarce 1-1/2 hp Sattley throttle governed engine built by Field & Brundage.
Link to that original post.
http://www.smokstak.com/forum/showthread.php?t=40278
After searching the forums here Randy Reysen was looking for information on these engines and did not find alot out there.
Here is a couple of links to some of Randy's older posts
http://www.smokstak.com/forum/showth...rosene+sattley
http://www.smokstak.com/forum/showth...=sattley+randy
Now the engine that was in the pictures was offered to me at the start of April this year. the engine had been worked on it but is not yet running. So on the way back home from the Le Sueur swap meet I stopped by and we made a deal on the engine and some other parts and pieces he had lying around. On the 7 hour drive home from his place to my home in Spiritwood i was puzzled why and how a Sattley engine was found on an old homestead in Saskatchewan. I had bought a bunch of old Macleods catalogues at an auction in 2013 and knowing that there was a relationship between Field & Brundage and Macleod's went through these old catalogues to see if i could find this engine. The Fall & Winter catogue from 1920 shows this engine 3 times. Scans attached.
ID:	196257   Click image for larger version
ID:	196258   Click image for larger version
The Following 3 Users Say Thank You to Will Batty For This Post:
Old 05-22-2014, 11:13:20 PM
Will Batty's Avatar
Images: 33
Default Re: Macleod, Sattley and Field Brundage
The engine was also in the Spring and Summer catalogue from 1920. So these 1-1/2 hp Throttle governed engines were being sold by Macleod's in Canada for sure between 1920-21. I do not have any 1919 catalogues so I do not know if they were offered earlier.
ID:	196260   Click image for larger version
Old 05-22-2014, 11:18:55 PM
Will Batty's Avatar
Images: 33
Here is a couple of pictures of the engine I bought. I will have to decide what i will do with the paint as by the catlogue the Macleods engines looked green.
If there is any interest, when I have more time I will start a thread and scan these Macleods catalogues as there is some good pictures/information on the Field & Brundage, Nelson Bros and some other engines the Macleods sold in Canada.
ID:	196262   Click image for larger version
The Following 7 Users Say Thank You to Will Batty For This Post:
Old 06-24-2015, 03:43:18 PM
Jim McCracken Jim McCracken is offline
I have a 1 3/4 McCleod hit & miss .It has a Webster mag and the remaining paint is red.
Serial # is 9392.
I don't have time for a picture today but I could get one later.
Sattley, Field Brundage what can you tell me? Will Batty Antique Gas Engine Discussion 7 04-17-2016 05:13:12 PM
Looking for some Sattley (Field-Brundage) dimensions and numbers Craig Solomonson Antique Gas Engine Discussion 1 03-28-2013 08:59:46 PM
Field Brundage Racene Sattley startup Mike King Antique Gas Engine Discussion 8 01-09-2012 08:29:41 PM
Indentifying a Field Brundage / Sattley Harry Antique Gas Engine Discussion 9 08-07-2008 02:17:36 PM
Magneto for a 5 HP Macleod or Sattley as built by Field Brundage spfx_dude Magnetos, Ignition Coils and Spark Plugs 2 07-03-2006 10:26:52 PM
