Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
Em6500sx won't start in cold weather
this thread has 65 replies and has been viewed 10077 times
Old 11-14-2013, 04:27:38 PM
yellowlister yellowlister is offline
Default Re: Em6500sx won't start in cold weather
wow.. whats up with your Honda dealer.. u can test the spark by taking the plug out and hooking the plug wire up to the plug and let it sit against the valve cover or something metal and pull it over see if u get a blue spark.
The Following 2 Users Say Thank You to yellowlister For This Post:
Old 11-14-2013, 05:13:03 PM
Rainayeh Rainayeh is offline
I just watched a YouTube video about testing the spark, the person was using a knock off honda generator but looked very similar. I will try it this weekend and if it is the ignition coil, hopefully my dealer can get me a new one.
I am wondering of it is the ignition coil, why would it start once in a while like it did last week a couple of times then stop,again .
Old 11-14-2013, 06:37:25 PM
Graycenphil Graycenphil is offline
It is sounding more like a bad low oil sensor, or possibly a bad ignition switch. Ignition module is possible, but less likely. The Honda dealer is sounding worse.
The Following 2 Users Say Thank You to Graycenphil For This Post:
  #34
Old 11-14-2013, 06:47:17 PM
I don't think it's the oil sensor, I disconnected the sensor cable, it had no effect.
I am puzzled to say the least, since it did start a few times last week after I changed the oil and fuel, that should eliminate many things. But as it is now, back to square one.
Old 11-14-2013, 07:00:05 PM
BlkBeard BlkBeard is offline
Maybe you should start a new thread and see if there's another Stak member close to you who has a bit more knowledge. you might be able to meet up with him/her and they could help you with the diagnostics/repair. look on ebay at spark testers. even if you don't buy one on there, it's a quick reference of the types available
The Following User Says Thank You to BlkBeard For This Post:
  #36
Old 11-14-2013, 07:02:06 PM
Kevin K Kevin K is offline
An inline spark tester is a tool you put in series with the spark plug, and watch for a flash (bulb type) or spark (gap type) when you crank the engine. It's the first test I do for a no start, because it quickly gives a go/ no go for the ignition system. Anyone working with engines should have one of each type.
Lamp type:
http://www.amazon.com/Lisle-20610-Inline-Spark-Tester/dp/B0002STSC6/ref=sr_1_1?ie=UTF8&qid=1384469639&sr=8-1&keywords=spark+tester
Gap type:
http://www.amazon.com/Thexton-THE404-Spark-Tester/dp/B0002STSBM/ref=sr_1_2?ie=UTF8&qid=1384469775&sr=8-2&keywords=spark+tester
  #37
Old 11-14-2013, 08:38:03 PM
If you tried it with the oil switch disconnected, that should rule that out. It does sound like something loose or making an intermittant connection. I'm afraid your dealer will just start replacing parts, at your expense, hoping to find what is wrong.
BTW, does anyone know for sure that disconnecting the oil pressure sensor on this engine will allow it to start? Is it possible you have to hotwire the switch instead? Robert@Honda, maybe?
The Following User Says Thank You to Graycenphil For This Post:
  #38
Old 11-15-2013, 10:59:42 AM
robertathonda robertathonda is offline
Doubtful it has anything to do with Oil Alert, since it does start sometimes. If the oil level were too low, it would never start.
My money is on the choke or carburetor, both of which can be picky about temps and starting (or not).
As mentioned before, the choke on this model is a bit complex, so any one part not working 100% would cause hard starting, especially a cold start.
-Robert@Honda
Caveat: I work for Honda, but the preceding is my opinion alone.
The Following User Says Thank You to robertathonda For This Post:
  #39
Old 11-16-2013, 07:28:58 PM
Warm weather here today, unfortunately didn't help, won't start.
As it could be a choke problem, I see no way I can fix it without taking to a specialist. Hope for a quiet winter so I don't need it . Thanx folks.
Old 11-16-2013, 09:22:29 PM
powerking powerking is offline
We've all given you plenty of things to try and look for, like myself and others have mentioned, you need to rule out certain things and be your own "tech" rather than bringing it to a dealer. spark testers should be available at your local auto parts store for a few dollars...get one..and rule out the ignition system
The Following User Says Thank You to powerking For This Post:
Generators in cold weather. alfieepstein Generators & Electric Motors General Discussion 17 05-05-2013 01:34:04 PM
Onan Emerald I will only stay started in cold weather with "START" held down onangeneratorhelp Onan Generators 5 10-23-2010 01:14:40 AM
Cold weather test Jeffw5555 Onan Generators 11 01-14-2010 10:04:23 AM
Onan DJE is REALLY hard to start in COLD weather ichudov Onan Generators 13 02-25-2007 08:17:56 PM
