Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
Storage of gen set with Gas?
this thread has 20 replies and has been viewed 1808 times
Old 01-09-2017, 09:44:26 PM
Phil P Phil P is offline
Default Re: Storage of gen set with Gas?
Originally Posted by Ronald E. McClellan View Post
Phil I do about the same thing. I drain the tank then run until it uses what is in the carb , then put in a few ounces of naptha , then run that out to clean the tank and carb. The naptha does not leave any residue/gum when it evaporates. Ron
Hi
When Avgas the new name for 100LL evaporates it leaves a white powder that will mix with any petroleum product.
Phil P
Old 01-10-2017, 10:23:11 AM
c east c east is offline
Thanks to all.....Charlie
Old 05-16-2017, 02:16:25 AM
Powertospare Powertospare is offline
I do that drain the bowl by running with fuel valve off till it stalls.
If I want to empty the tank fast I use a siphon hose and put the gas in a container and then in my truck.
What I would like to know for my generator which is a Champion 46534, does the tube inlet inside fuel tank going to the valve outside the fuel tank, stick up a small amount from the bottom of the tank to keep dirt out of the carb.
I cant see inside well. There is a small detent made in the tank that is lower than the rest of the tank where the valve is installed.
I got most all the gas out with the siphon, but nothing comes out the fuel valve.
If I were to unscrew the valve I could then empty it all, but am always afraid of the idea, if it aint broke don't mess with it. I've know stuff to break why you least expect it. Getting a replacement part when otherwise then generator works fine.
Rather than trying to take the tank off so I could hold it upside down and empty and shake the last drips out, seems like too much trouble. Just air out to evaporate after a non-lint type cloth blot out the last amount I though of.
How have you handle this issue?
Old 05-16-2017, 08:25:42 AM
Amax Amax is offline
I add two cycle oil to the gas and then drain the carb or close the petcock and run it dry. No fuel storage problems even with today's E10 gas.
Old 05-16-2017, 08:02:24 PM
AlexV AlexV is offline
I store all my Generators dry. I rotate my fuel that I have in no spill can's every 6 months. aviation gas sounds like a good idea but I have no way of rotating it. I can't put it in my truck or car.
Old 05-17-2017, 06:42:51 AM
powerking powerking is offline
also, make sure your not under a load when you let the carb run out......AVR's dont like that
Old 05-23-2017, 12:53:08 AM
richard.bessey richard.bessey is offline
Just don't do it, especially if its a smaller unit (Honda EU2000I)!
If it were me, based on my experience, I would mix up some fuel with fuel stabilizer in it. Put some in the tank, run it for a good 20 minutes. Then shut down, remove as much fuel as possible (I have used a fuel pump and pumped it out of the tank) and then fire the genset up and let it burn whatever is left out of the tank.
The larger gensets, in my experience are not as cranky with old fuel
Old 05-31-2017, 07:26:27 AM
Arkie Arkie is offline
I store some small gen's for several years without starting the engine.
I completely drain the gas tank and remove the fuel bowl on the carb and dump gas, then I install ATF fluid in the tank and let it go to the carb.
I remove the spark plug and install little bit of ATF and crank engine over and replace plug and leave spark plug wire off. Then attach a tag that the system has ATF and to clear before gas.
The ATF keeps metal tanks from rusting. I've removed them from 10 years of storage, clear the fluid and ready to go.
Some carbs, like Honda have a small drain on the bottom of the carb bowl and the bowl does not have to be removed for draining oil or gas.
Just trying to run a carb dry will leave some fuel in the bowl which when evaporates leaves a residue to clog the carb.
When removed from storage 10 minites of clearing ATF and she is ready to go instead of hours of working on carb and fuel systems on gas engines.
Propane converter is also good option for long term storage of gas gen's.
Old 06-04-2017, 03:43:20 AM
On a another forum I found some one said use of a old turkey baster to suck the left over gas that draining does not get in the fuel tank. Taking the tank off or turning a 130 pound gen upside down is not an easy task. Now what to baste? No turkeys were harmed....
The use of running the last run of the engine with fuel stabilizer as here it was said to do, sounds sensible although I have not done that, it will be done. It was just to move the gen for a short while in a vehicle, I was feeling uneasy with a big tank of gas.
Thanks.
Old 10-27-2017, 09:19:01 PM
Newoldstock Newoldstock is offline
This should be available in the USA now, it is in Canada.
https://duckduckgo.com/?q=aspen+fuel...ai=imrFqyTDtEA
I swear by this stuff.
I even cheat ( yes I am a cheater at the track, all is fair in love war and race day ) and use this because I think I get faster lap times on it.
Buy the 2T and 4T.
Use them to flush your fuel system and rinse your tank out ( one has oil to prevent rust the other does not. )
This fuel require no additives or preservatives and I am told it will stay fresh for 5 years.
SO if you do leave a little in your carb or tank in the process of flushing your fuel system it will not gum anything up.
I have talked this product up for years ( even when it was really expensive and hard to get ).
No one has ever come back and said to me that I was wrong ( or right ).
That's too bad, tells me no one is listening...
This true fuel stuff is something I am suspicious of, but I am sure you could use it to flush a fuel system too.
I am not sure exactly what it is but I smell aromatic rings added to it like Xylene ( this is what gives 100LL its low vapour pressure and long life as well as high octane but they use a regulated level not to harm aircraft engines ).
Xylene can eat up rubber parts in engines so even though I use it to this day as a fuel additive in its pure form I am careful to remove it from my fuel systems.
https://www.homedepot.com/p/TruFuel-...7238/203572162
The Aspen fuel is real safe to use on all engines and will not attack rubber like the aromatics in other stabilized fuels.
The better product of the two by far and both cost the same.
Buy the 2T and 4T.
I wanted to add I was introduced to Aspen at an antique engine show in the USA by a fellow that ran engines on it that did not want to have to go to all the trouble of flushing 10 ethanol gas from their old iron. ( I could smell something was different about the engine so stopped to asked )
It even smells nice on the fair ground to be around engines running it.
Ask around and maybe you can chat some of these guys up about next time you are at a show....
Boiler Storage willyjasper Steam Stationary Engines, Traction Engines, Steam Boats 2 01-08-2015 08:25:13 PM
Engine storage R Towne Antique Gas Engine Discussion 5 12-18-2014 03:23:35 PM
Mag Storage Farmer John Antique Gas Engine Discussion 16 05-13-2010 04:55:02 PM
Saw Storage Sky Garden Tractors / Mowers / Scooters 8 12-15-2008 10:18:35 PM
Another Mogul comes out of storage Tom Sampson Antique Gas Engine Discussion 13 09-19-2006 05:28:30 PM
