Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
Honda ES3500 Generator
this thread has 21 replies and has been viewed 1697 times
Old 10-26-2017, 03:19:19 PM
americancopier americancopier is offline
Photo Honda ES3500 Generator
Just bought a Honda ES3500 at an estate sale this weekend.Got it cheap but is missing the carburetor and related hardware.I did manage to get it running after cleaning the points and using a gas soaked rag as a carb.I was hoping someone might have a scrap engine they could sell me that has the parts I need,I think it is a Honda G80.The generator appears to have little use and would love restoring it.
ID:	294413   Click image for larger version
ID:	294414   Click image for larger version
Old 10-26-2017, 04:18:50 PM
robertathonda robertathonda is offline
Default Re: Honda ES3500 Generator
I can verify the carb has been long gone / discontinued from Honda. Might try eBay for an NOS one, or maybe a clone?
Robert@Honda
Social Media Consigliere
Caveat: I work for Honda, but the preceding is my opinion alone.
Old 10-27-2017, 08:50:31 PM
Newoldstock Newoldstock is offline
I was at tractor supply recently and saw what looked like a G100 on a brand new minibike.
I am 99% sure this engine is still being made as a clone in China.
https://www.tractorsupply.com/tsc/pr...bike-105cc-ohv
This car direct from China might work.
https://www.aliexpress.com/store/pro...12f124325fMWhd
Old 10-27-2017, 09:50:30 PM
Thanks,that does look like a close fit.My engine needs the throttle actuator on the side for the governor to work unfortunately.Not sure but I think it is a g80 engine on the generator.The engine has the exhaust on the front side and most newer ones have it on the rear.Hope that could narrow down what engine is on it.
Hard to believe Honda discontinued parts for this already.Dont think it’s more than 40 years old!
Old 10-28-2017, 07:16:55 PM
Those G motors are very old.
They were designed in the 60s as a direct response to Honda trying to get into the US market and seeing how companies like Clinton were crushed by B&S or Tecumseh.
The Honda solution was to build a really good engine on par with the best in the industry but from aluminum ( not iron so they were light like the other brands ).
The success of these aluminum engines with ball bearings and iron liners forced B&S for example to match them in quality ( the IC series ) and try to beat them on price ( volume ).
The follow up to this story is the GX series from Honda.
All eggs in one basket and so forth it had to be significantly better than the G series to command a premium price in the market....
The great irony is the Chinese did something Honda and Briggs could not do.
Build a GX engine at cheaper than low end consumer grade Briggs prices.
Your not surprised your local autoparts store does not provide EOM parts for your 72 Polara, but you do expect Honda to support products almost as old.
There again are those Chinese that clone everything.
I am sure if you search hard enough not only will Aliexpress find you parts, but complete clones of G motors and other brands.
This is not a unique to China situation by the way.
This is not a restored Villiers, its a clone made in India.
---------- Post added at 07:16:55 PM ---------- Previous post was at 07:13:01 PM ----------
I thought I should add a photo of a Mk25 for the purists....
I love these engines sadly they are so rare over here.
Old 10-28-2017, 07:43:02 PM
Thanks for the Honda history! This makes it all the more worth restoring this old but like new generator.I don’t expect Honda to support their products for ever but hoping for at least an after market supplier.The carb does appear to be too unique to easily match up.I know someone has a g Honda engine for parts,just a matter of time.
Old 10-29-2017, 07:15:29 PM
Anything you can make fit off another 4 stroke of about the same displacement and performance will work.
Easier if you can turn some screws to adjust it..
You would be surprised what you can graft together to make work.
I was in Cuba on holiday and saw all kinds of old American cars that are running because the mechanics are very good at adapting parts to keep things running.
Here's an interesting video of a clone GX200 ( 196cc with a carb off an engine 150 cc larger ).
I bet you can adapt something from another Honda product or clone.
https://www.youtube.com/watch?v=PQ9U7flWop0
Old 10-29-2017, 07:49:37 PM
Honda made it really difficult to retrofit a modern carburetor..The mounts are at a 45 degree angle and the choke and the throttle and choke shafts are horizontal.
Old 10-30-2017, 10:34:31 AM
Yes I know.
There are many aftermarket kits that allow you to use a GX390 carb for example on a race prepared GX200, or a Tilllotson kit that allows you to use one of a number of aftermarket carbs with a standard flange pattern.
There are even adjustable jet kits that let you turn screws on jap carbs.
How badly you want to fix something you can not find the correct parts for is entirely up to you.
I think if you head over to your local small engine shop and explain the problem you might find the right carb or the owner might have something you can adapt.
If you are going to build an adapter I suggest a thick aluminum plate with studs for the new carb and recessed Allen head cap screws for the adapter.
Old 10-30-2017, 10:39:28 PM
That still wouldn’t get around the problem of getting the governor to work with vertical throttle controls.the control rod pulls from the bottom and connects to the side of the carb.
Honda ES3500 info YellowLister Honda, Yamaha, Kawasaki, Isuszu Generators 26 11-29-2017 09:15:26 PM
Honda ES3500, Taming a screamer. Combustor Honda, Yamaha, Kawasaki, Isuszu Generators 9 05-19-2015 03:11:30 AM
Honda generator? Twin34 Honda, Yamaha, Kawasaki, Isuszu Generators 3 09-11-2013 07:44:49 PM
Honda Generator Jesse Zilafro Honda, Yamaha, Kawasaki, Isuszu Generators 1 02-17-2009 05:14:13 PM
Honda generator Roger DiRuscio Honda, Yamaha, Kawasaki, Isuszu Generators 0 02-10-2004 01:14:56 AM
