Oil Field Engines
Tutorial on CDI ignitions?
this thread has 20 replies and has been viewed 1885 times
Old 08-26-2016, 07:42:35 PM
Reed Engine's Avatar
Default Tutorial on CDI ignitions?
Mags aren't used often anymore on engines people rely on to run 24/7. Don't get me wrong, mags are fine and have their place if you want period correct but the truth is the quality of mag parts isn't a fraction of what it was 20-30 years ago. It just this simple, mags are not the best choice anymore. Like it or not the CDI ignitions are here to stay. So my question.
Would there be interest here in me doing a tutorial on how to install them?
The Following 3 Users Say Thank You to Reed Engine For This Post:
Old 08-26-2016, 08:18:25 PM
C-Wade7 C-Wade7 is offline
Default Re: Tutorial on CDI ignitions?
I would be curious to see the set up used.
Old 08-26-2016, 08:59:52 PM
The same principle as your lawn mower, no moving parts in it's self but uses the flywheel to generate the electricity.
Old 08-26-2016, 09:28:20 PM
I'm curious on how the magnet is placed and if it uses a module like a motorcycle or coil unit like Briggs can it be added to any flywheel engine and how do you find placement?
Old 08-26-2016, 09:57:48 PM
That's part of what I would be showing how to do.
The Following 2 Users Say Thank You to Reed Engine For This Post:
Old 08-27-2016, 11:35:36 AM
tyrion's Avatar
tyrion tyrion is offline
Images: 42
Yes Please do a Tutorial and thank you in advance!
Old 08-27-2016, 11:59:56 AM
stufforbud stufforbud is offline
Yes, I'm ready too!
Old 08-28-2016, 08:54:14 AM
Dale Carnahan Dale Carnahan is offline
Look at an airplane, they run on two they use them because they are reliable.
---------- Post added at 07:54:14 AM ---------- Previous post was at 07:52:23 AM ----------
Mags that is
Old 08-28-2016, 02:21:34 PM
At least in the day, airplanes used Bendix magnetos. They were/are very very good. The reason Bendix isn't used on most oil field engines was you could buy a FM mag for less than it cost to overhaul a Bendix. I'll put it this way, would you really want to fly in an airplane that used FM mags?
Old 08-28-2016, 03:23:13 PM
But they use 2 for redundancy, because sometimes they quit.......
Many planes today have 1 CDI and 1 mag.
Old 08-28-2016, 04:50:44 PM
OK, back to the OP. I'll show how to install a "601" ignition on either a Fairbanks Morse or an Arrow C series. The method used is the same for any other engine. This will probably end up on Youtube.
Old 08-30-2016, 11:00:39 PM
Here's a simple version until I get something more in depth.
https://www.facebook.com/permalink.p...72595763396115
Old 08-31-2016, 01:17:59 AM
I get a "page not found" response to your link, Reed.
Doc
"i'm here tonight as living proof that not every American boy can grow up to be President." - Barry Goldwater, 1973 celebrity roast
Old 08-31-2016, 01:47:40 AM
Whats a 601 ignition system? Yep, thats a dead link.
Old 08-31-2016, 11:21:54 AM
601 was the reference Fairbanks Morse gave it when they developed it if I have my facts straight. The first one I ever saw was about 30 yeas ago, it had a brain box about the size of the first solid state ignitions Ford used during the 70's. They were a flop. FM more or less forgot about the thing and later i years a company called Dynelco (sp?) took the design and because circuits had been reduced in size and improved in quality they started making the ignition and called it the Star Fire. Then came several others who did likewise calling it whatever but they all were and are still a 601 design. FM even re released the thing. Personally I use Arrow Engine's copy as it is as good a quality out there and the price is just as good or better.
Old 08-31-2016, 01:07:10 PM
David A. David A. is offline
please post your diagrams, thanks
Old 08-31-2016, 01:24:59 PM
Try the link now please.
Old 08-31-2016, 05:56:05 PM
link works great, thanks, where do I go to get parts to build one and what do I ask for
Old 08-31-2016, 06:33:21 PM
There are several brands out there. I use the Arrow unit and an aftermarket stand.
Old 08-31-2016, 09:50:08 PM
joder joder is offline
Any thoughts on pilfering a starfire system out of an old lawnmower - could it be made to work? Might bring the cost down significantly if it's doable.
Radiator tutorial vern0n Antique Autos and Trucks 10 02-12-2014 05:10:53 PM
Oiler Tutorial How about? dboles Antique Gas Engine Discussion 10 04-17-2013 06:25:42 PM
Ignitions Jesse Zilafro Small Air Cooled Gasoline Engines 3 09-14-2012 01:29:35 AM
Tecumseh OH 160 Ignitions Ed Stoller Welding Shop 1 12-08-2011 10:02:18 AM
ignitions ajo enterprises Antique Gas Engine Discussion 2 01-11-2006 06:07:00 PM
