Kohler Generators
Kohler R series manual available here
this thread has 19 replies and has been viewed 5340 times
Old 01-17-2013, 09:35:44 PM
Daverepair Daverepair is offline
Default Re: Kohler R series manual available here
If you do a search I posted a 20ROP81 diagram somewhere here.
Look here Kohler shop Manual 20ROP81 spec.13302B28
Correction, Search that in Kohler section
The Following 2 Users Say Thank You to Daverepair For This Post:
Old 01-25-2013, 12:47:54 AM
HomesteadTX HomesteadTX is offline
Dave,
Got it, downloaded fine. Thanks!!!!
Jarrett
Old 12-08-2018, 09:42:22 PM
Oldsparks Oldsparks is offline
Originally Posted by Daverepair View Post
http://www.fileswap.com/dl/VHcMJFFbP...-5110.pdf.html
Please leave a note if you get it successfully
Just joined and tried to download the manual for a Kohler 12.5 R 62 to no avail. Said the page could not be found. The problem could be on my end. Any help would be appreciated. Thanks
Old 12-09-2018, 09:17:38 AM
wa5dxp wa5dxp is offline
Got "Server Not Found"
The Following User Says Thank You to wa5dxp For This Post:
Old 12-09-2018, 10:10:16 AM
dkamp dkamp is offline
eMail NOT Working
Yep... I think Fileswap.com is AWOL, or their DNS has been botched.
12.5R62... I believe that's 230 3phase DELTA, four cylinder Waukesha FC140, 32v battery start, remote connections on terminals 5 and 6 ...
Am I right?
Old 12-09-2018, 10:41:22 AM
Kevin K Kevin K is offline
The manual link was an old post from April 2012 and links go bad quickly on the internet.
12.5R62:
12.5 = 12,500 watts
R = remote start
6 = 120/240 single phase 3 wire
2 = Combination Gas/Gasoline or Straight Gas
Read the Kohler FAQ sticky on top of the threads for a lot more information. Unlike Onan, the Kohler model number is not very specific. We need the spec number to find information on what you have. Pictures are welcome and very helpful.
The abandoned link was to manual TP-5110 which covered single phase R series models 5RMY, 5RMOY, 7RMY, 7.5R, 7.5C, 10RY, 10RMOY, 15RMY, 15RMOY, 17RY, and 17.5ROY.
Old 12-09-2018, 04:19:17 PM
No, it's single phase either 12.5 or 11 kw with a 4 cylinder continental engine.
---------- Post added at 03:19:17 PM ---------- Previous post was at 03:16:23 PM ----------
12.5R62:
12.5 = 12,500 watts
R = remote start
You are on the money spec wise. The model number says 12.5 but the spec tab says 11kw so which is correct? thanks
Old 12-09-2018, 04:35:49 PM
Oldsparks;1536007]Just joined and tried to download the manual for a Kohler 12.5 R 62 to no avail. Said the page could not be found. The problem could be on my end. Any help would be appreciated. Thanks
Some pics of what I have. 12.5KW or 11KW. Need to size breaker. Thanks
ID:	324219   Click image for larger version
ID:	324220   Click image for larger version
ID:	324221   Click image for larger version
ID:	324222   Click image for larger version
Old 12-09-2018, 05:40:47 PM
Looks like you have an older exciter cranked revolving armature generator with a Continental Y112 engine. Not too much literature is available on those older units. From the controller spec number C-268326F, you need wiring diagram C-268327, which can be obtained from a Kohler distributor as described in the sticky FAQ.
Engine service manual here:
http://manuals.chudov.com/Continenta...aul-Manual.pdf
And here:
http://pipeweldrig.com/files/weld/Co...l%20manual.pdf
Parts manual link here:
https://www.smokstak.com/forum/showthread.php?t=152273
Old 12-09-2018, 09:37:09 PM
Thanks for the help
Wico C Series Service Manual? KD5BYB Magnetos, Ignition Coils and Spark Plugs 0 09-22-2011 09:43:57 AM
DD 53 series Service Manual DLeach Vintage Diesel and Oil Engines 6 06-24-2011 12:46:32 PM
Need help locating manual for Onan 4.0 BF series hogryder Onan Generators 7 05-27-2011 03:40:25 PM
Onan B series Service Manual Ed in Va. Onan Generators 3 11-29-2010 09:05:12 PM
Kubota 05 Series Manual Available Ted_Cool Generators & Electric Motors General Discussion 0 04-28-2008 06:10:46 PM
