Kohler Generators
1965 Kohler 6.5R22 to be Placed into Service
this thread has 112 replies and has been viewed 4600 times
Old 11-19-2018, 01:23:35 AM
Motorhead's Avatar
Default Re: 1965 Kohler 6.5R22 to be Placed into Service
keith, unless that little piece is cheap from Kohler, you can measure the thickness and possibly find some cork gasket material and cut to size one. The rear main seal might be a rope type seal instead of a one piece rubber seal. The rope type seal usually is in two pieces. One piece fits in a groove on the block, then you install the crankshaft. The other piece fits into a grove on the rear main bearing cap. You use some good silicone sealer where the rope seal halves meet.
My 1939 WILLYS Pickup.
Bought in 1971
Old 11-19-2018, 02:19:16 PM
Vanman Vanman is offline
I think it was 3 bucks and change. Expensive for a piece of cork, but the correct size and shape already so...
The rear seal is a rubber lip seal on these. But I'll bet my favorite old Kohlers made from the '20's through the '40's have something like a rope seal.
Old 11-19-2018, 09:36:09 PM
Motorhead's Avatar
I agree... Cheap enough. With "Today's" silicone sealants, you could probably just put a dab of sealant between the cap and block. I always use a dab of silicone sealant at the sharp corners where the cam bearing cap meets the head when installing an over-head cam valve cover gasket. I would seal the cork pieces in place.
Bought in 1971
Kohler 6.5R22 - I'm Stumped. Somebody help me here! dkamp Kohler Generators 25 03-31-2016 02:05:53 AM
Kohler 3.5R22 rmm727 Kohler Generators 4 06-15-2014 09:09:17 PM
kohler 5kw 5R22 electric plant crancreature Kohler Generators 5 12-24-2012 11:47:53 AM
Kohler electric plant help 1.5R22 don smith sr Kohler Generators 4 07-26-2008 01:10:40 PM
Just got a Kohler 1.5R22 MarioMaster Kohler Generators 20 02-13-2008 11:59:53 AM
