Kohler Generators
Kohler S800 Electric Plant
this thread has 54 replies and has been viewed 1935 times
Old 09-24-2018, 10:29:16 PM
Vanman Vanman is offline
Default Re: Kohler S800 Electric Plant
Looking good!
Here is a muffler shown in the 1929 manual.
And another...
And the last one is the muffler used with a housing. No pictures, just a diagram. The rather flat looking thing at the top.
ID:	319498   Click image for larger version
ID:	319499   Click image for larger version
Old 09-24-2018, 10:29:47 PM
Zephyr7 Zephyr7 is offline
Default Re: Kohlrr S800 Electric Plant
That thing is beautiful! It looks like you just bought it new! Even the paint looks perfect!
You definitely scored big time with that find!
Bill
Old 09-24-2018, 10:49:57 PM
And here's some more stuff on the vacuum tank.
ID:	319501   Click image for larger version
Old 09-25-2018, 12:11:31 PM
Newoldstock Newoldstock is offline
It would be interesting to run the number on those old lighting sets and see what you get for efficiency.
I have a gut feeling they are probably pretty good.
Old 09-25-2018, 01:56:15 PM
ssv54tpp ssv54tpp is offline
I am sure it is effeciant also, once I get it running correctly and all set up I am just going to let it go for a while . Still have some paint chips to touch up,maybe idk if I will fix them or let them be.
Old 09-25-2018, 03:05:38 PM
G Sams G Sams is offline
When I was using my Model E and my 1A21 for charging my 144 volt battery bank, they would charge 11 to 12 amps for 13 hours on 5 gallons of gasoline. Considering their low compression ratio, I always thought it was amazing.
Old 09-25-2018, 06:16:38 PM
So I bought a old factory cart as a different idea for an engine cart, also to hold the batteries and mount a period correct lamp with the pamphlets as a display of everything. I thought this would be different.
The Following User Says Thank You to ssv54tpp For This Post:
Old 09-27-2018, 06:03:41 PM
OK so I replaced the rotor,cap,point and condensor. It ran for a little while kinda rough during to crappy fuel still in some mlm parts and the timing not set yet. I shut it off to do something and now it won't start, it has no spark at the plug wire side. I did nothing to the ignition system. I am stumped now. Anyway here is a short video of it running. https://youtu.be/-K7L3pi9k38
Old 09-27-2018, 07:28:46 PM
I went to do a little investigating and discovered that the post on which the rotor rests on moves a little up and down, so I pulled it up which raised the rotor and it started. So i ran it for 10 min and it produces electricity, shut it off and now the plugs are fouled. So time to figure out the intake.
Old 09-29-2018, 07:16:46 PM
Here is a short video, we are making progress. https://youtu.be/aY02VuHmIh4
Kohler electric plant 3.5cm 21 chip23 Kohler Generators 8 10-18-2015 10:52:02 PM
Kohler electric plant thumper56 Kohler Generators 9 01-30-2013 02:50:45 PM
Kohler electric plant jason tucker Kohler Generators 0 09-08-2008 08:35:30 PM
Kohler Electric Plant Bert Hamilton Antique Gas Engine Discussion 1 07-28-2006 08:56:26 AM
Kohler Electric Plant Mark Bruce Kohler Generators 0 06-10-2003 03:08:08 AM
