Kohler Generators
Kohler S800 Electric Plant
this thread has 54 replies and has been viewed 1937 times
Old 10-30-2018, 01:06:30 PM
Vanman Vanman is offline
Default Re: Kohler S800 Electric Plant
I'm not sure about the carburetor, but I do know that Kohler usually had overflow lines connected to them, draining back to the tank. I'm sure this was done to make indoor operation safe. The fuel tank was outside, under ground, a couple feet below the plant.
Old 10-31-2018, 03:54:34 PM
ssv54tpp ssv54tpp is offline
Yes that is correct, there is an overflow/return line back to the tank from the fuel bowl. I believe I will use copper crush washers for the gilts and cork sheet for the gaskets. That should work. I did find another carburetor on ebay from Denmark, so n bought it as a spare for parts if needed,and just because it is so old not to many out there.
Old 11-08-2018, 07:24:07 PM
So the carberator is now not leaking, and the engine runs much better. I still can not get the fuel pump to work though. I have gone over every connection and can not figure out why it is not pumping fuel. I do have vacuum coming from the manifold.
Old 11-19-2018, 05:26:01 PM
I now have the fuel.pump working correctly, I ran the generator for 4 hrs the other day without any issues.
The Following User Says Thank You to ssv54tpp For This Post:
  #55
Old 01-03-2019, 06:27:02 PM
Well, I had a new shunt coil made and wired it In the control box. IT WORKS when plug and unplug the small heater. Success.
The Following 3 Users Say Thank You to ssv54tpp For This Post:
Kohler electric plant 3.5cm 21 chip23 Kohler Generators 8 10-18-2015 10:52:02 PM
Kohler electric plant thumper56 Kohler Generators 9 01-30-2013 02:50:45 PM
Kohler electric plant jason tucker Kohler Generators 0 09-08-2008 08:35:30 PM
Kohler Electric Plant Bert Hamilton Antique Gas Engine Discussion 1 07-28-2006 08:56:26 AM
Kohler Electric Plant Mark Bruce Kohler Generators 0 06-10-2003 03:08:08 AM
