Kohler Generators
Kohler 12 RES Installation
this thread has 93 replies and has been viewed 2466 times
Old 11-17-2018, 10:53:04 AM
zaphod zaphod is offline
Default Re: Kohler 12 RES Installation
so it's the other way around: Winco is high voltage and Kohler is low. Anyway throwing a grand at it worked for this phase. Now to attack the speed sensor.
Oh yeah, he had to put in a 120V line to power the on board battery charger; the WINCO unit had it built in the ATS.
Old 11-17-2018, 07:16:45 PM
Mark Dieckmann Mark Dieckmann is offline
That makes sense.
Old 11-19-2018, 04:03:12 PM
so I have a bad speed sensor, the gen defaults to OS immediately on startup. I bought the new sensor, and learned the original is located under the unit. I cut away a bit of the plastic fan shroud and located the flywheel next to the inspection port and mounted the new sensor to the back cover. I get resistance but no signal voltage. I'm using a 0.48 paper shim (installation says to shim between 0.31 and 0.71 ") any ideas? Sensor has resistance, just no signal on cranking. Shouldn't it generate around 3.5 volts AC?
Cheers,
Zaphod
Old 11-19-2018, 06:32:26 PM
Cheers,
Zaphod
Further to my previous post: Found my problem, fairly easily solved. The service guy who came out here (supremely un-motivated) told me the sensor "counts teeth" So I assumed there were magnetic plates inside the flywheel around the perimeter. I should have just discounted the guy as an idiot. Rotated the flywheel until I saw the mag block, measured the distance to mid mag block from the shroud backing plate (29.87 mm or 3 cm including midpoint mark on the sensor) fabricated a block from a piece of pine, drilled and tapped the backing plate and mounted the sensor so I can get at it from below the oil cooler. No one can tell me Kohler couldn't have done it this way to begin with, alright: maybe they would have used aluminum instead of pine, but the repair works, is adjustable and in my hostile climate a welcome respite from service calls at $90 per hour including travel. Booyah!
Old 11-19-2018, 08:12:42 PM
Zephyr7 Zephyr7 is offline
Magnetic pickup speed sensors do “count teeth”, and they don’t need any magnet on the flywheel to work. Mag pickups sense the variation in metal distance between the sensor and the teeth as they go by (the top of a tooth is a shorter distance than to the bottoms of the gap between adjacent teeth.
The overspeed condition is usually sensed by something other than the mag pickup. By using a seperate sensor, overspeed conditions caused by a failed mag pickup can be detected.
I’d advise against using wood to make mounting brackets on a genset. Metal would be much better, steel or aluminum. If you need something easier to work, try a piece of acetal (also known as Delrin). It’s a very durable plastic but still easier to work than metal. I wouldn’t trust wood to work long term anywhere tight tolerances are needed.
Bill
The Following User Says Thank You to Zephyr7 For This Post:
Old 11-24-2018, 06:29:49 PM
Redesigned my system, using a Ford crankshaft sensor, I put inside a modified 1/2 ID plumbing fitting and attached to the shroud plate with a metal bracket. I shimmed it at 048" and it fired right up. The sensor is now under the oil cooler, readily available. Not too pretty but very practical.
Oh yeah: total cost: $21.25.
Cheers,
Zaphod
Old 11-24-2018, 11:52:40 PM
Just make absolutely sure your setup is solid. If the sensor pops off and gets wound around a shaft youíll be having a very bad day. Loose sensors will make for erratic speed too which can cause all kinds of problems for electrical equipment.
Be careful. Kludges have a way of coming back to haunt you later.
Iím not sure why youíre so concerned with replacing a mag pickup anyway. They are very reliable and rarely fail.
Bill
Old 11-27-2018, 05:02:50 PM
Bill
Hi,
Because the unit wouldn't run at all without it. I can't get a straight answer from Kohler here and replacing the speed sensor solved my problem.
Now I have an under-voltage problem After running perfectly, the set now shuts down after 10 seconds with UU code for under voltage. I found a blown fuse, replaced it, and the set ran for about 10 minutes, then blew the fuse. Now with proper fuses in place, it still shuts off and gives me the UU code. Any ideas?
Cheers,
Zaphod
Old 11-27-2018, 06:14:38 PM
What voltage is it actually producing while running? If it puts out correct voltage, but shuts down on under voltage, then your undervoltage trip is set too high and needs to be lowered. If it’s putting out low voltage, then I’d guess the regulator needs adjustment or may even have failed.
A blown fuse makes me suspect wiring issues or something in a winding, but let’s hope for now it was either a too-small fuse, or a fluke. A bad regulator trying to go full field could have popped a fuse too.
Bill
Last edited by Zephyr7; 11-27-2018 at 10:41:14 PM. Reason: Said overvoltage but meant undervoltage
Old 11-27-2018, 07:28:15 PM
Email NOT Working
Is it the fuse in series with the auxiliary (regulator power) winding? 55/66 IIRC?
High resistance brushes or some other excitation problem can cause that fuse to blow, due to the regulator circuit needing higher power than normal.
Just speculation here.
[Based on extensive experience with these. This would be a rare problem but not unheard of.]
DC generator installation ? Gene Fisher Antique Gas Engine Discussion 6 01-23-2014 05:57:07 AM
Oil ring installation? Rusty derby Antique Autos and Trucks 3 08-25-2013 09:09:22 PM
Kohler 8.5RES LP gas installation? mkaiserco Kohler Generators 3 09-01-2010 01:04:39 PM
magneto installation IHC 6hp M R Towne Magnetos, Ignition Coils and Spark Plugs 3 08-30-2010 09:53:58 AM
Gib Key Installation? doug s Antique Gas Engine Discussion 3 05-25-2009 09:17:36 PM
