Kohler Generators
Kohler 12 RES Installation
this thread has 93 replies and has been viewed 2462 times
Old 11-29-2018, 10:37:12 AM
Zephyr7 Zephyr7 is offline
Default Re: Kohler 12 RES Installation
Zaphod, please post back here and let us know what the problem turns out to be. Thatís how we all learn
Bill
Old 11-29-2018, 05:51:00 PM
zaphod zaphod is offline
Well, I figured this generator is powered by infinite improbability anyway. I'll tear into the electronics tomorrow. It starts and runs but only generates 52 volts now, so I think something in the output side went kablooey. I'll check the brush resistance and get back to you all manana - I'm in Maine and it's windy out tonight.
Old 11-30-2018, 02:41:59 PM
OKAY: I got into the box, disconnected the FN ands FP leads from the SCR. Resistance is 3000 Ohms. No voltage when gen starts AC or DC (normal). If I had to guess I'd say the SCR has shit the bed. 55 Volts when running before UU shutdown. Any thought? I'd have to cut the screws holding in the panels obstructing the brushes, so I'm hoping I don't have to go there.
Cheers,
Zaphod
Old 11-30-2018, 04:54:09 PM
Email NOT Working
3000 ohms on the wires going to the generator? Or on the terminals of the SCR?
The SCR is tested differently. Like a diode. I'll look for the procedure later if you like.
Old 11-30-2018, 07:02:53 PM
If that 3,000 ohms is the field resistance measured through the brushes, then you definitely have a problem with the brushes. No way should the field be up in the kilohms like that.
Bill
Old 11-30-2018, 07:36:54 PM
Mark Dieckmann Mark Dieckmann is offline
Sorry I haven't been paying attention. Those SCR's can fail. I don't recall the test procedure. Also there is a test where you feed battery voltage into FN and FP and check output. I don't recall what the output should be but it will confirm that the problem is elsewhere and not the alternator itself. I may be able to look up the test procedures if you don't have them.
Old 11-30-2018, 08:05:27 PM
Email NOT Working
The output will be roughly 1/2 normal if you feed battery to FP and FN. You will also get 50-100 volts on 33-55 IIRC, something like that.
But we don't know where he got the 3k yet. On the FP/FN leads or across the SCR pack?
Old 12-02-2018, 07:15:09 PM
Got the resistance on the FN/FP leads. I ____ed up: it's actually around 300 Ohms.
Tested the SCR like a diode and have a dead leg on the + side so I figured 55 volt output was half the 110 nominal it should be channeling. Things are pretty gnarly in there: I sprayed the board, plugs and connectors with water dispersant then cleaned off the terminals. Amperage means resistance so I think something is impeding flow. My thinking is: I got 120+/- at first then 240 (open circuit unregulated) then 55. Feels like a thermal breakdown and the only part of the circuitry subject to thermal flux is the SCR. Am I right? It's going to cost $110 to find out. If I'm wrong I have to tear the generator case down to get at the brushes and windings. Doesn't "feel" like a winding as the low voltage is constant and no smoke, no heat from the generator casing but I will defer to more informed opinions.
The SCR can fail. If what I've read is true they do so catastrophically. I have a dead leg on one side. I don't have thyristor testing equipment but on a rudimentary level I think I can tell if it's pooched.. Cheers.
Old 12-02-2018, 07:22:03 PM
Not all multimeter diode checkers run enough voltage to check some thyristors (fancy term for SCRs and triacs). You might read bad even if itís not unless your tester is running maybe 4-5v+ for the test.
I still think you have a problem with the brushes.
Bill
Old 12-02-2018, 10:04:43 PM
Email NOT Working
300 ohms is no good, stop there, do not mess with the SCR until you have the brushes sorted out.
You need to get the back and side off and take off that housing around the brushes and see what is going on in there. Don't do anything else until you have this part figured.
Brushes should be 5-15 ohms or something like that.
DC generator installation ? Gene Fisher Antique Gas Engine Discussion 6 01-23-2014 05:57:07 AM
Oil ring installation? Rusty derby Antique Autos and Trucks 3 08-25-2013 09:09:22 PM
Kohler 8.5RES LP gas installation? mkaiserco Kohler Generators 3 09-01-2010 01:04:39 PM
magneto installation IHC 6hp M R Towne Magnetos, Ignition Coils and Spark Plugs 3 08-30-2010 09:53:58 AM
Gib Key Installation? doug s Antique Gas Engine Discussion 3 05-25-2009 09:17:36 PM
