Kohler Generators
Kohler 9CC061-RV
this thread has 10 replies and has been viewed 433 times
Old 11-26-2018, 12:11:45 PM
Motorhead's Avatar
Default Re: Kohler 9CC061-RV
If it is rubber mounted, check the mounts for any cracks or fatigue. Fortunately, it looks like the outer frame for the radiator is built very stout. If you have no history on the coolant, I would highly recommend doing a drain, light flush with citric acid granules and change the thermostat and any hoses that look in poor shape. I use Zerex G-05 and distilled water or better yet is the Zerex red diesel rated coolant and distilled water. Try to find the cooling system TOTAL capacity and then top it off with the distilled water. I say this because there is always some residual rinse water left in the engine. By putting 1/2 of total capacity of coolant FIRST, you are insured to get a 50/50 mixture.
I have used the citric acid flush since my Mercedes diesel days. Mercedes recommends it as a thorough but gentle cleanser that doesn't take out the water pump. If you need a water pump, change it now before the coolant change. Don't buy the pump or thermostat from Kohler but from YANMAR after market. Lots cheaper.
My 1939 WILLYS Pickup.
Bought in 1971
Vintage Kohler: Help With Identifying This Old Kohler : SethPattillo Unidentified Engines 2 06-24-2017 08:58:34 PM
Kohler Kohler K 161 T (1978) on Troy Built Tiller weak spark youngbill1946 Magnetos, Ignition Coils and Spark Plugs 3 06-10-2015 09:38:11 AM
Kohler Kohler 300W Belt Generator Heelerman Kohler Generators 3 10-09-2014 10:46:38 AM
Kohler 3.5RM62 Spec. 620 H.3.4.5.7 with kohler A-23858 information bobfish1 Kohler Generators 2 08-13-2013 10:21:18 AM
KOHLER of KOHLER Electric Plant rvaccaro2 Kohler Generators 2 05-03-2013 12:52:46 PM
