Kohler Generators
Muffler?
this thread has 4 replies and has been viewed 407 times
Old 11-12-2018, 07:54:39 PM
Tbirddillon Tbirddillon is offline
Default Muffler?
What muffler have you guys used to quiet the L600 down? Mine is straight pipe and quite loud. Any tips on removing an elbow someone threaded in the manifold I've tried everything I could think except the acetylene torch?
Old 11-12-2018, 10:00:56 PM
jack0 jack0 is offline
Default Re: Muffler?
Mufflers for compact tractors work well.
Weld a 1-1/4 pipe nipple in the muffler and use a union on the manifold.
Removing the elbow might involve cutting it off with a sawzaw.
Leave some material sticking out of the manifold.
Cut down to thread level in 2 spots close to each other.
Small chisel to dislodge small piece.
Crush remaining piece inward and thread it out.
If you do it right you barely nick the threads.
Old 11-12-2018, 10:48:17 PM
Zephyr7 Zephyr7 is offline
You’ll probably need to either use torch or saw to get that elbow off. The heat tends to corrode things together (why I like to use stainless for exhaust parts). If you heat it up with a torch, try to heat the outer piece the most, then see if you can yank it off or break it loose with a twist. If it stays really stuck even after a few heat/cool cycles then it’s probably saw time.
Use the heat to expand the metal a tiny bit to break it free. Don’t “glow” the metal or otherwise soften or cut it with the torch.
Bill
Old 11-12-2018, 11:24:04 PM
Thanks guys, I guess I'll try to find a torch to borrow if that doesn't work then cutting time.
Old 11-16-2018, 11:17:26 PM
Well I was able to get it out with an air chisel and cut off wheel. By the way stanleymuffler.com has loads of options with all the measurements.
Muffler Roger Kirschenman Antique Gas Engine Discussion 4 08-07-2012 10:22:07 PM
muffler #2, can anybody id Meco3hp Small Air Cooled Gasoline Engines 9 07-07-2012 11:05:38 AM
muffler, can anybody id Meco3hp Small Air Cooled Gasoline Engines 4 07-06-2012 12:40:14 AM
Onan stock muffler 155-1258 or cheap Car muffler(s) HondaBob Onan Generators 2 01-21-2010 08:03:48 PM
Muffler ID Mark Bruto Antique Gas Engine Discussion 5 07-17-2008 08:28:49 PM
