Kohler Generators
Kohler k301 diy oil pump and filter
this thread has 30 replies and has been viewed 1076 times
Old 11-20-2018, 07:59:49 PM
Gregothegreat Gregothegreat is offline
Default Re: Kohler k301 diy oil pump and filter
Where do u post pictures I just go a free motor.
Old 11-20-2018, 11:12:25 PM
dkamp dkamp is offline
eMail NOT Working
What I would do... If I wanted to do what George was doing...
I'd put a small belt-drive off the crank, to slow-turn an SBC oil pump, that would lift oil from say... about 6" off the bottom of a 5-gallon tank... and pump it up THROUGH a thread-on filter adapter, to a tank that's a few inches to a foot above his engine. From that tank, would be an overflow tube, that when the oil level got above overflow, it would drain down the tube, into the engine's crankcase, to some point BELOW the normal 'Full' line.
In the crankcase, I'd drill and tap a hole into which a fitting would thread, that would be just barely above the FULL line... from there, a tube to overflow, and go back down to the lower tank.
This would not only give him filtration, cooling, and capacity... IF the oil pump system failed, it would NOT drain the sump... it would just stop flowing the additional oil.
As for recapturing heat... it's a flathead... a guy could make a liquid-cooled head without much difficulty... and even boost the compression to give the NG more to work with... a thick piece of steel or aluminum, carefully milled with recesses to clear the valves, and a threaded hole for the plug... and then drill crossways holes for plumbing in some tubing to transport cooling water... That's essentially what the K-series 'marine' generator head was... but Iron.
  #23
Old 11-21-2018, 07:04:21 AM
Exhaust would be an easy place to capture waste heat.
  #24
Old 11-21-2018, 10:41:17 AM
I all ready use the motor heat to heat my shop at the end of a 7 hr run my 700 sq ft shop is tee shirt temp, the shop is attached to my dog boarding kennel and with the shop warm it somewhat helps to warm the dog farm.
https://photos.app.do not use shorte...mdZRFynhHGZBx6
My latest skore free.
https://photos.app.do not use shorte...4ERtmXHLmBK8NA
Try that
Ok them links don't work what a circle jerk. Ok try Greg's junk Facebook group
Old 11-21-2018, 12:28:52 PM
John Newman, Jr.'s Avatar
Many here do not do Fazebook.
Please upload pictures directly to the SmokStak site. Below the box where you type your reply is an area labeled "Additional Options". In there is a button saying "Manage Attachments" Use this to put your pictures in your post. That way the pictures are not subject to third party hosting problems.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
The Following 2 Users Say Thank You to John Newman, Jr. For This Post:
  #26
Old 11-21-2018, 02:44:48 PM
Im look in but I must be having a seniors moment just don't see additional options. Ok I found it
ID:	323302   Click image for larger version
ID:	323303   Click image for larger version
The Following 2 Users Say Thank You to Gregothegreat For This Post:
  #27
Old 11-21-2018, 02:49:06 PM
Newly acquired free not stuck could get running. He has more I think Sunday I'll be getting more. These will be coming from an old machinest motor collector who's time had come to go to old age home.
The Following User Says Thank You to Gregothegreat For This Post:
  #28
Old 11-21-2018, 07:47:45 PM
Newoldstock Newoldstock is offline
OH you lucky boy!!!!!!!
Old 11-22-2018, 11:39:45 AM
BHoward BHoward is offline
What make engine is it?
Old 11-23-2018, 09:30:55 AM
It is an Arrow c46, develops a whopping 9 -11 up and only weigh 1000 lb. 600 rpm or less.
Kohler K301 Help Newbie28 Kohler Generators 13 03-23-2015 08:38:08 PM
Kohler K301 No Spark Jailer Magnetos, Ignition Coils and Spark Plugs 1 09-06-2014 12:46:30 PM
kohler k301 Tom Kilgore Small Air Cooled Gasoline Engines 4 05-11-2013 11:47:42 AM
Kohler K301? Bigger45 Kohler Generators 1 08-21-2009 09:01:28 AM
Need Kohler k301 help Tom Jamboretz Small Air Cooled Gasoline Engines 9 11-05-2007 11:11:35 PM
