Kohler Generators
Kohler 12 RES Neutral/Ground Connection
this thread has 12 replies and has been viewed 429 times
Old 12-17-2018, 07:37:23 PM
Email NOT Working
Default Re: Kohler 12 RES Neutral/Ground Connection
I wouldn't install it unless you find you actually need it. Nobody I know has one and lots of off grid.
Old 12-17-2018, 08:21:32 PM
Zephyr7 Zephyr7 is offline
The carb heater is just an aide, not totally required. Itís not like a block heater on a diesel that can be required to even get the unit to start at all.
Without the carb heater, in really cold weather, your unit might start a little rougher but you should be ok. You probably wonít notice much difference at all.
Bill
Old 12-17-2018, 11:51:12 PM
TNBob TNBob is offline
Thanks Birken Vogt
Thanks, Bill
Ground roof top antenna to neutral-ground of power line? sdowney717 Generators & Electric Motors General Discussion 43 12-12-2013 09:38:09 PM
Onan 6.5 NHD separating ground from neutral? Magnetite Onan Generators 11 03-27-2012 03:58:03 PM
Need INFO on neutral and ground c east Generators & Electric Motors General Discussion 12 08-29-2011 08:01:47 PM
neutral or ground OMCposty Generators & Electric Motors General Discussion 3 10-14-2005 02:08:19 PM
MEP017A neutral/ground John T Military MEP and Aircraft Gen-Sets 1 10-02-2004 09:07:49 PM
