Kohler Generators
Kohler 20rz eating starters; (won’t stop cranking)
this thread has 10 replies and has been viewed 513 times
Old 01-07-2019, 02:55:24 PM
Ozark Lee Ozark Lee is offline
Default Re: Kohler 20rz eating starters; (won’t stop cranking)
I had the same issue with a 30REOZ.
I initially had trouble with it not starting so I replaced the solenoid with whatever was the cheapest Ford solenoid from the O'Reilly Auto Parts that was about a block away. It started fine and exercised normally for about a month and then it missed an exercise and would not start again. I VOM'd it to the starter and it was getting power to the starter but no crank. Kohler wanted nearly $800.00 for a starter and John Deere, surprisingly, was about about $50.00 cheaper. I did some leg work and found a rebuilt on eBay for a skid steer that uses the same engine for $150.00. I installed the new starter and things were good again and I gave it several cycles. On the 3rd or 4th cycle I caught it not releasing the starter after the engine started and I quickly shut it down manually.
The problem traced back to the solenoid that I replaced with the cheap auto parts store part was sticking so I went to Kohler and bought the OEM part and haven't had any trouble since (about 2 years). The auto parts store version looked the same, wired the same, and initially behaved the same but the $15.00 savings was expensive. I have no idea what is so different between them but the auto parts store versions are trouble.
...Lee
Kohler 20RZ HELP PLEASE Alphahouse Kohler Generators 18 01-19-2017 06:52:55 PM
Onan 15.0 RJC wont stop cranking/Remote Starting krc002 Onan Generators 6 07-04-2016 12:11:21 PM
Kohler 20RZ Radiator sinklar Kohler Generators 13 05-23-2016 06:50:51 PM
Looking at Buying Kohler 20RZ opsman Kohler Generators 11 03-10-2011 09:34:07 PM
Chance to buy a Kohler 20RZ Jasonl007 Kohler Generators 1 06-12-2009 03:26:41 PM
