Kohler Generators
Governor Adjustment
this thread has 16 replies and has been viewed 620 times
Old 12-08-2018, 05:21:53 PM
Default Re: Governor Adjustment
Originally Posted by Tbirddillon View Post
...the legs aren't marked. How do I know what leg does what?
Yes they are, look on the side of the case.
Old 12-08-2018, 05:25:03 PM
Note the "AC" near the corner.
Old 12-08-2018, 05:40:16 PM
Tbirddillon Tbirddillon is offline
Ahh ok I thought it was just stating information not designating that side of it as AC. Thank you.
Old 12-08-2018, 05:48:48 PM
Each corner will probably be marked "AC", "+" or "-" respectively. Most of the time, the "AC" terminals are diagonally opposite.
Old 12-08-2018, 08:11:35 PM
Zephyr7 Zephyr7 is offline
AC May also be marked as “~”. DC out will be the usual + and -
Sometimes one corner is beveled, in which case that corner is +. The opposite corner diagonally will be - and the remaining two corners are the AC terminals. On your specific rectifier, the + terminal will be the one that is rotated 90* with respect to the other three. The other three terminals are as a described for the beveled corner example.
Bill
The Following User Says Thank You to Zephyr7 For This Post:
Old 12-09-2018, 10:05:25 AM
dkamp dkamp is offline
eMail NOT Working
Tbird -
If you happen to confuse the field + and field - wires, when you start the gen, she'll generate output, but when your load increases, the voltage will drop.
Don't ask how I know...
Old 12-11-2018, 07:57:40 PM
Newoldstock Newoldstock is offline
Default Re: Governor adjustment
Originally Posted by Vanman View Post
Lastly, (should have been first) are you still running the square finned Selenium rectifier in the control box? If so I would advise against running the set with load until it is replaced with a Silicon recrifier. If the rectifier fails, the compounding transformer will be ruined. It would have to be rewound as they are not an off the shelf component.
Vanman is right about the adjustments thats how you do it.
Replace the rectifier
Don't get clever and fuse it.
CTs much never be left open in a circuit under a load or major over voltages can happen that ruin them
If you must disconnect it because of rectifier failure short it.
YES short the CT out.
Never leave it open
LB Governor Adjustment jboyer1028 Antique Gas Engine Discussion 4 07-01-2014 09:04:24 AM
12 hp Reid governor adjustment Ron Haskell Oil Field Engines & Related Equipment 2 10-23-2013 10:32:11 PM
2 1/2hp Economy XK governor adjustment? bustedmp Antique Gas Engine Discussion 6 05-26-2011 06:44:41 PM
Need help on governor adjustment Donald A Smith Antique Gas Engine Discussion 2 06-18-2007 09:16:46 AM
Governor adjustment Christopher Brewer Kohler Generators 2 10-16-2004 08:21:48 PM
