Kohler Generators
Kohler PDFs Available
this thread has 167 replies and has been viewed 55358 times
Old 06-14-2010, 08:55:22 AM
grizzlytfs grizzlytfs is offline
Smile Re: Kohler PDFs Available
I have a KOHLER CONFIDANT 5, 5CKM21 Spec# 101243 and need all manuals, service user and the like. Thanks and you can send to me at kb7voo@comcast.net Thanks again.
Old 06-16-2010, 10:53:11 AM
NikkiW NikkiW is offline
Default Re: Kohler PDFs Available
I was wondering if any of those would be for a electric plant
model 6.5R61
ser no 267406
spec no 505002347
kw 6.5
kva 6.5
rpm 1800
hp 12.5
volts 240/120
pf 1
battery volts 12
phase 1
cycles 60
Old 06-25-2010, 01:10:39 PM
jwt27ta6 jwt27ta6 is offline
Hello, I could use the repair manual for a propane kohler 4ckmr62 manual, SN #288041 Spec#101313, 4k watt. It is on a 1993 RV.
Mine doesn't even begin to start, all you hear when you push the start button is a buzz in the control panel...it isn't the starter solenoid. 1 guy told me that my be the fuel solenoid making the buzzing. Regardless, neither the starter or starter solenoid is doing anything.
The battery is good. My next step is to chk voltage to generator & starter solenoid. I suspect it is a relay bad in control box, but need manual or a good tech to direct me.
xnks
Jeff
Old 06-29-2010, 12:53:03 AM
GNation GNation is offline
i have a 4ckm21 model. u have any manuals on that model?
Old 06-29-2010, 08:41:58 AM
xnks
Jeff
Update: The starter solenoid was engaging, but even when I jumped across it manually, I got nothing. And when I measure the Voltage on solenoid when trying to start, it would get pulled down to 0V. After moving starter manually & moving the gear in & out into flywheel & some Liquid Wrench, I eventually got starter to start spinning & engaging. I broke the solenoid stud in process, but can manually jump it now & getting working.
It looks like just a standard solenoid, so hope I can match one up @ Auto store.
Old 08-14-2010, 11:27:18 PM
bhw2ijp bhw2ijp is offline
yes I need a service manual for kohler 4.5ckm21-rv
bhw2ijp@verizon.net
Old 09-03-2010, 01:11:41 PM
fuzzyswede fuzzyswede is offline
I just purchased a Kohler Generator at a local auction, Model 350 C 21K7, Spec 300 2A with a Tillotson MD30A carburator. It was in poor shape but complete, after extensive cleaning, etc., I got it running but need information for the correct governer / carburator linkage adjustment and carburator settings.
I would really appreciate a copy of your manuals for the following:
Kohler K-Series-Engine-Owners-Manual TP1436-C
Kohler K-Series-Engine-Service TP2379 11-92
Let me know your charges when sending to mthyberg@westriv.com
Thank you very much,
Mike
Old 09-22-2010, 01:33:02 AM
petecosentino petecosentino is offline
Thanks for posting this I need the Kohler 4.5ckm21-rv service manual TP5206
Thanks a million
Pete
let me know if there is any charge
e-mail peter.g.cosentino@dom.com
Old 09-22-2010, 05:33:06 PM
RETCPO RETCPO is offline
Rob,
I could use PDF files for the following
Kohler 4-5CKM Service Manual TP5394 12-94a
Kohler 4CM21-Owners-Manual TP1040-527
Each a separate e-mail please.
Kleach5926@aol.com
Keith
Old 09-27-2010, 11:35:43 PM
avrej avrej is offline
Keith,
My name is Jim and I have a Kohler 4.5 generator set that needs work. I could really use some help like your pdf service manual; Kohler 4.5 ckm21-rv service manual TP5206.
my email address is
avrej@yahoo.com.
Thank you for your time and consideration,
Jim Avre
KOHLER of KOHLER Electric Plant rvaccaro2 Kohler Generators 2 05-03-2013 12:52:46 PM
Kohler K12-2 Steam Pig Kohler Generators 3 08-12-2012 09:23:33 AM
Wisconsin & Continental Engine Manuals--Free PDFs Jud Generators & Electric Motors General Discussion 1 03-15-2007 11:11:36 AM
Kohler gen-set Al Wait Kohler Generators 1 10-06-2005 08:02:30 PM
Kohler 2 cyl.gen,set. Arthur Kohler Generators 1 07-21-2005 10:27:53 PM
