Sparta Economy ID
this thread has 11 replies and has been viewed 1419 times
Old 10-03-2017, 08:55:13 AM
kelden kelden is offline
Default Sparta Economy ID
I just bought I believe a horse and a half Sparta,not sure. Looks like my economy except the oiler is behind the water tank and has a one bar Webster mag. No tag on it,but complete otherwise. any help please.
Thanks, Kelden
Old 10-03-2017, 09:09:05 AM
Just bought this Economy with no tag,otherwise complete. Looks like my one and half econ except oiler is behind the water cooler and has a single bar Webster. Any advise will help.
Thanks. Kelden
Old 10-03-2017, 10:16:59 AM
Tom Cwach's Avatar
Tom Cwach Tom Cwach is offline
Default Re: sparta econ ID
Need picture. D series had no tag. Serial number on end of crankshaft. Open top water hopper.
Old 10-03-2017, 12:03:51 PM
Thanks. Kelden
Sounds like a model "E". A photo would confirm that. What model is your other Economy?
Old 10-03-2017, 03:56:57 PM
Kelden,
I'm not a Sparta expert but the Webster mags didn't come on the Economy's until after Hercules took over late in 1913-14. So that probably isn't a Sparta. Others can weigh in as I said I'm not an expert. You'll probably find you answer though otherwise looking through the Sparta threads.
Kevin
Old 10-04-2017, 07:56:28 AM
my other one is a model E, 1923 Rounded corners on water hopper and oiler tube thru
water hopper. This one has more sharp corners, also oiler behind hopper with a one bar Webster.
Thanks for any help.
---------- Post added at 07:56:28 AM ---------- Previous post was at 07:54:34 AM ----------
Thanks, I will check.
Old 10-04-2017, 08:18:18 AM
The earlier "E" engines are as you describe. I don't know exactly when the oiler tube was moved, but it was late in the "E" engine production. With a date of 1923, I am surprised your other engine isn't tagged as an "F".
Old 10-04-2017, 12:21:08 PM
Default Re: Sparta Economy ID
Take a close look at the ends of the crankshaft. On the early engines, the S/N was stamped into the crank. I has a 1913 Hercules, and it was as you described except that it has a single magnet Webster Tripolar on it. S/N started 51---
Old 10-04-2017, 09:03:11 PM
Dave Nielsen Dave Nielsen is offline
If it is a Sparta it will have the Lunkenheimer mixer on it. The 1hp, 1 1/2hp Sparta's, D's, and early E's had a elongated water hopper opening. Not the standard square opening as on the later Economy's. A picture would help. The early 1hp Sparta's had the governor in the cam gear and not the standard fly ball governor.
The Following 2 Users Say Thank You to Dave Nielsen For This Post:
Old 10-05-2017, 11:50:19 AM
Thanks, Kelden
If you go here:
http://www.herculesengines.com/hercules/econ_pics.html
and scroll down to the middle of the page, you will see several photos of a typical model "E" Economy. Further down the page is a model "F" engine which I am guessing looks like your "other engine". Near the top of the page are photos of Sparta and "D" engines. They are quite distinctive.
Sparta Economy Tim Rostar Antique Gas Engine Discussion 22 10-03-2017 07:57:37 PM
Sparta Economy ID kelden Antique Engine Photos 1 10-03-2017 03:56:57 PM
Sparta Economy CX 6HP Mrnick Antique Gas Engine Discussion 3 04-13-2017 12:47:34 PM
Sparta Economy HP D Davis Antique Gas Engine Discussion 10 10-24-2011 09:10:55 PM
1hp Sparta Economy Rich Hudak Antique Gas Engine Discussion 6 07-20-2011 11:56:49 AM
