Restoration of 1918 Stewart Truck
this thread has 70 replies and has been viewed 23825 times
Old 05-06-2013, 01:19:51 PM
Troy Vetsch's Avatar
Troy Vetsch Troy Vetsch is offline
Post Re: Restoration of 1918 Stewart Truck
My Stewart truck will be using modern detergent oil, because it will have been overhauled. If it hasn't been overhauled and you use non detergent oil, I would say keep using that kind. You could switch over to the modern oil, but expect frequent oil changes since it will loosen some of the heavier oil inside the engine.
Troy
The Following 4 Users Say Thank You to Troy Vetsch For This Post:
Old 05-06-2013, 04:01:09 PM
vern0n vern0n is offline
Default Re: Restoration of 1918 Stewart Truck
Originally Posted by Jeff LaCrone View Post
I have a Model T and have been told to use non detergent oil if you don't have a filter. Any thoughts? Thanks
If the engine is a fresh rebuilt, then use detergent. If it has been run non detergent for a long time than stay with non detergent. You don't want the detergent to wash all that crud off and circulate through the engine.
The Following User Says Thank You to vern0n For This Post:
Old 08-20-2013, 11:07:17 PM
Here we are measuring the crankshaft bearing surfaces to figure out how much out of round the crankshaft is. We used a digital caliper and a micrometer for precision measurement. I measured four different places on each bearing surface. Then afterwards we used a Timesaver Compound to grind the crankshaft into the bearings. That way we have a good, smooth surface for the crankshaft to ride in.
ID:	172906   Click image for larger version
ID:	172907   Click image for larger version
ID:	172908   Click image for larger version
The Following 7 Users Say Thank You to Troy Vetsch For This Post:
Old 08-21-2013, 01:56:00 PM
Exclamation Re: Restoration of 1918 Stewart Truck
You should have the block boiled and chemically cleaned, if you plan to use detergent oil. Detergent oil will clean EVERY hidden surface, putting the gum and gunk into suspension in the oil. As the engine has no filter, this material will find its way into cam bearings and all babbitted bearings as well. With non detergent oil, gum and dirt in the system will not be loosenned, and any dirt in the oil will settle in the bottom of the crankcase, as you have found.
I would recommend a 500 mile break in with non-detergent oil, then a removal of the engine pan for inspection. If no debris (carbon, metal chips, sludge) are found, then from then on, use detergent oil, with frequent oil changed (every 2000 miles). In al reality, with no filter, frequent oil changes should be regimin - in this case, there is no real advantage in detergent oil, due to the required frequent oil changes.
Old 09-09-2013, 11:57:26 PM
Lightbulb Re: Restoration of 1918 Stewart Truck
After we got done working on the block, the next step is the transmission. First we headed over to Allen Severson's shop and I power washed the transmission after we wrapped the clutch in plastic. We then tore the transmission apart back at Rogers' shop and found parts of a bearing in the bottom. So we found out we needed to make a thrust bearing for the clutch/transmission.
ID:	174432   Click image for larger version
ID:	174433   Click image for larger version
ID:	174434   Click image for larger version
The Following 8 Users Say Thank You to Troy Vetsch For This Post:
Old 09-20-2013, 08:30:04 AM
Huber Huber is offline
I enjoy reading about the work that you and Roger are doing on the Stewart. I bought a 1920 IHC truck and found first gear broken in 4 pieces in the bottom of the transmission. Sometimes a mechanical break down on these old trucks causes them to be put aside for repairs before they are worn out and inadvertently preserved. Jim
The Following User Says Thank You to Huber For This Post:
Old 09-20-2013, 09:16:00 AM
Jack Innes Jack Innes is offline
The oil question is often discussed with different views. The principles involved should be clear; In an engine without an oil filter non detergent oil is intended to let the "crud" that you found in the pan to settle & remain undisturbed until you remove the pan & clean it out, usually at the next ring & valve job. In an engine with an oil filter, detergent oil is intended to keep the impurities in suspension to be continuously removed by the filter.
Two conclusions can be made;
1. Detergent oil without a filter constantly circulates the abrasive impurities through your bearings.
2. Detergent oil introduced into an old engine that has been used with non detergent oil will loosen up great quantities of "crud" & possibly clog oil passages with undesirable results.
A clean rebuilt engine can usually handle detergent oil & with very frequent oil changes may be safe but the non detergent oil would be safer with longer change intervals.
My father who owned a new & used car dealership & was a licensed mechanic starting in the 1930s, saw the inception of detergent motor oil & repaired a great many ruined engines from its use. He was always very adamant about never putting detergent in an old or unknown engine.
The Following User Says Thank You to Jack Innes For This Post:
Old 09-20-2013, 06:18:45 PM
You make some good points Jack. My guess is this topic will have pros and cons depending on who you talk too. Air cooled VWs didn't have oil filters, but the factory recommended detergent oil. The thinking is, if you start with a clean engine and change the oil every 3,000 miles there isn't going to be much crud suspended in the oil, and what crud there is will be flushed out at oil change. Now let me muddy the water some more. Are there any non detergent synthetic oils for gas engines? If there is, I bet you can't go down to wally world and buy some.
Old 09-20-2013, 06:30:07 PM
If an engine is bad enough that cleaning it up with detergent oil turns it into an oil burner it was shot anyway.
This is going to be a "new" engine.
I much prefer to drain oil with all the crap coming out with it than having it accumulate in the bottom of the pan.
There is no reason for Troy to not use detergent oil.
I can't remember the last time I bought non-detergent oil.......
The Following 4 Users Say Thank You to Craig A For This Post:
Old 09-20-2013, 07:43:50 PM
TonyClemens TonyClemens is offline
I've been using Mobil Delvac 15w40 in the 6 cylinder flathead engine that's in my '56 White WC22PLT. I don't know what was orginally used. I do know that it had a hydraulic lifter that was tapping and now that I've driven the truck and changed the oil several times it has quieted down. I pulled the oil pan to clean out the sludge and there wasn't any there. The engine does have a sock type oil filter.
The Following User Says Thank You to TonyClemens For This Post:
Stewart Truck Troy Vetsch Antique Autos and Trucks 2 12-09-2012 04:43:21 PM
White 1918 Good Roads Truck Heins Antique Autos and Trucks 6 07-30-2012 12:58:51 PM
Stewart Truck Wayne Riedlinger Antique Autos and Trucks 8 10-26-2011 10:56:44 PM
More truck pictures, Stewart and Seldon bstrucker Antique Autos and Trucks 3 09-10-2008 01:28:38 AM
1918 REO Speedwagon Truck RIRR Antique Autos and Trucks 11 05-23-2008 01:09:56 AM
