Restoration of 1918 Stewart Truck
this thread has 70 replies and has been viewed 23834 times
Old 09-22-2013, 12:09:35 AM
Troy Vetsch's Avatar
Troy Vetsch Troy Vetsch is offline
Default Re: Restoration of 1918 Stewart Truck
Since we found the remainder of a bearing, the choice was to find one or make one. We ended up making a thrust bearing to fix the problem. We machined two brass rings on the lathe. Then drew out and spaced the ball bearings in the circle we made on the rings. After that we drilled the correct sized holes and then counter sunk them to allow the balls to float between the two rings. After we were all done we then soldered the two rings together and assembled the transmission and clutch as a whole again.
Before final assembly we had to also make two new cork seals for the end plates of the transmission.
The Following 3 Users Say Thank You to Troy Vetsch For This Post:
Old 11-08-2013, 12:42:32 AM
Smile Re: Restoration of 1918 Stewart Truck
After we got the Transmission assembled we started working on the wheels to get them sealed. We used a sealer called Kwik-Poly. You have only a couple of minutes to work with it until it sets up hard. Then fully hardens in 24 hours or so. Roger and I sealed 3 of the 4 wheels without making any new pieces. Although the last one, I needed to make a section of the wood rim.
ID:	179060   Click image for larger version
ID:	179061   Click image for larger version
ID:	179062   Click image for larger version
The Following 9 Users Say Thank You to Troy Vetsch For This Post:
  #23
Old 11-08-2013, 08:29:50 AM
Jeff LaCrone Jeff LaCrone is offline
Looks like your doing a good job! I believe that piece of the wheel is called the "fellow".
The Following User Says Thank You to Jeff LaCrone For This Post:
  #24
Old 11-08-2013, 10:48:42 AM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
For one thing non detergent oil is not readily available from most regular outlets these days. It gets back to the basics of use, as stated above cruddy accumulations in the motor are the result of poor maintenance and worn rings. If the thing burns oil, crud will build up in the crankcase no matter what the oil used. If the motor is clean and in shape, regular service intervals will keep it that way. If your motor is in need of a rebuild the oil used isn't going to make much of a difference, kind of like those magic little motor overhaul in a bottle kits. The only thing they did was humor the buyer into thinking he was really doing something good. Just a side note on that wheel repair, I believe you will need to replace those spokes where the rim was rotted as they will keep shrinking and never stay tight. I have a few here that are in the same shape and am looking for practical ways to correct them. Never seen the rim repaired in 2 pieces like that before so will like to hear how it holds up. There are a few old time wheel wrights in the Amish communities that do those type wheels but can get pricey and their not close by here. F.J.W.
Old 11-09-2013, 11:06:26 AM
Huber Huber is offline
Thanks for the update on the Stewart. I bought a 1920 International truck. I had two front wheels made and used parts of the front fellows to fix the back wheels. It has worked well .
The Following 8 Users Say Thank You to Huber For This Post:
  #26
Old 11-10-2013, 08:00:20 AM
Elden DuRand's Avatar
Images: 11
Jeff:
I know this is nitpicking but it's spelled "felloe".
Now, I could be wrong and probably am.
Take care - Elden
http://www.eldensengines.com
The Following 4 Users Say Thank You to Elden DuRand For This Post:
  #27
Old 11-13-2013, 10:24:02 PM
I have been doing some sanding and painting on one of the front wheels. The Kwik-Poly sands very nice and paints well. I also used some body filler to fill in the deep gouges. Next will be to work on the rubber on the wheel.
The first picture is of wheel hub primed and the wood with the first coat of red paint.
The second picture is with the steel rim painted black and the first coat of red paint on and it is sanded down, ready for the second coat of paint.
The third picture is the finished product.
Name:	Stewart front wheel 1.jpg
ID:	179468   Click image for larger version
Name:	wheel red paint sanded.jpg
ID:	179469   Click image for larger version
Name:	red finished on front wheel.jpg
The Following 6 Users Say Thank You to Troy Vetsch For This Post:
  #28
Old 11-13-2013, 11:06:43 PM
Arrow Re: Restoration of 1918 Stewart Truck
Nice work Troy.......
We had a 1923 Sterling truck in the shop.
The front rubber was SO out of round we could hardly drive the thing.......
I couldn't swing the wheel in the lathe soooooooooo we jacked up the front end, clamped on every vice grips we had and spaced them equally around the rim to act as a "pulley" for a flat belt, took the cross slide off of our big lathe and clamped THAT to a heavy steel horse.
We used a BIG drill that has a 6" 3 jaw chuck on it to drive the wheel like a pulley.
Set up a sharp, SHARP, cutting tool and faced off the front tires to make them round and smooth.
Worked like a champ.......
(photo courtesy of Aumann Auctions)
The Following 4 Users Say Thank You to Craig A For This Post:
  #29
Old 11-19-2013, 11:46:34 PM
I finished my first wheel yesterday (Monday), all of the pin striping is done in black. It worked out very well for doing it by myself and for my first time ever.
ID:	179925   Click image for larger version
ID:	179926   Click image for larger version
ID:	179927   Click image for larger version
  #30
Old 11-21-2013, 01:11:30 PM
Here are the front wheel bearings. They are for both front wheels. There is a bigger and a smaller one all inside the hub. They cleaned up nice and work well. Notice the shoulder on the bearing and the ridge for it to ride in in the raceway.
Name:	wheel bearing 1.jpg
ID:	180048   Click image for larger version
Name:	wheel bearing 2.jpg
ID:	180049   Click image for larger version
Name:	wheel bearing 3.jpg
Stewart Truck Troy Vetsch Antique Autos and Trucks 2 12-09-2012 04:43:21 PM
White 1918 Good Roads Truck Heins Antique Autos and Trucks 6 07-30-2012 12:58:51 PM
Stewart Truck Wayne Riedlinger Antique Autos and Trucks 8 10-26-2011 10:56:44 PM
More truck pictures, Stewart and Seldon bstrucker Antique Autos and Trucks 3 09-10-2008 01:28:38 AM
1918 REO Speedwagon Truck RIRR Antique Autos and Trucks 11 05-23-2008 01:09:56 AM
