GMC 1928 T20 Truck Restoration
this thread has 31 replies and has been viewed 5279 times
Old 02-23-2018, 01:47:05 AM
Oldtech Oldtech is offline
Default Re: GMC 1928 T20 TRUCK restoration.
Hi GMC. Yes, I have seen the ones without the cap on the bottom, and yes, I think you should get it to the closest tooth. The point cam can then be loosened for fine tuning I think. Timing mark is a bit of a puzzle, Yes, there's a 17 degree mark but there should also be a 0 or a TDC. Maybe truck flywheel is different, I have one in shop, maybe I can check this weekend. # 1 cylinder is the front one.
Firing order... I will double check. There was a change somewhere in there. One instruction I have says use the 7 degree mark with the lever in full retard, which makes sense.
The Following User Says Thank You to Oldtech For This Post:
Old 02-24-2018, 12:22:55 AM
GMCtrucker GMCtrucker is offline
Hi there Oltech.
I will closely check the flywheel this weekend too and try to make photos of the marks on it.
I really appreciate your effort in helping us.
Old 02-24-2018, 09:32:14 PM
Back at it. I looked at 2 flywheels and the mark reads either UDC or DC. over 1-6
Translation . Upper dead center cylinders 1 and 6. I had mistaken the C for an O. in the rust. The engine I looked at is a 1928 and it appears the firing order is 142635, so yours is likely the same. I have a 27 with wires still on it but it is out in the snow.
Your distributor is likely the modern type with the mount clamped to the dist body so it can be loosened if you need to adjust the position. So... To time it, from the start.
get #1 on firing position - either by watching valve action or holding thumb over the spark plug hole while cranking, and set to the UDC 1-6 mark. Move the lever on steering column to full retard position. (distributor full clockwise). Decide which rotor position will be number 1 and set the distributor so the points are JUST GOING TO OPEN. Clamp it there, then install the wires clockwise 142635. Should work. My apologies for the confusion, sometimes my memory isn't what I think it is. I will watch this thread if you have any more questions.
The Following 2 Users Say Thank You to Oldtech For This Post:
  #24
Old 02-25-2018, 11:37:07 PM
Default Re: GMC 1928 T20 Truck Restoration
Thanks Oldtech, your help is very appreciated.
Will try the procedure you just sujested and will tell. We have the same flywell marks you have.
Do you have a photo of your car to share? Hope I can see yours
ID:	304135   Click image for larger version
The Following User Says Thank You to GMCtrucker For This Post:
  #25
Old 02-26-2018, 07:56:03 PM
I'm not sure what the 17 degree mark is about. Mine doesn't seem to have it. Ill try to put a couple of project pics.
Old 02-28-2018, 12:01:09 AM
I found my 1926 Reference book. They have a convoluted method of timing the distributor using the 17 degree mark. I like my method better. It confirms firing order 142635
Old 03-04-2018, 01:07:58 PM
Thumbs up Re: GMC 1928 T20 Truck Restoration
Thats cool. Ours is running better. Just dealing with the idling which I believe is the Marvel carb. Adjustment.
Thanks for all your help Oldtech.
Old 03-06-2018, 01:24:49 AM
Yes, adjusting marvel carbs is a bit of black art Basically... set the big knob flush with the end of the lock spring, then adjust the mainjet on the bottom for best high speed operation, then fine tune the big knob for idle. I think the settings change whenever the temp or barometer changes. Are you running a vacuum tank?
Old 03-14-2018, 12:23:15 PM
Montyfromalberta Montyfromalberta is offline
If you want the manual for this I can email to you.. it's a in a PDF..
Send me an email if you want. Mono36@gmail.com
Cheers
The Following User Says Thank You to Montyfromalberta For This Post:
  #30
Old 03-16-2018, 12:28:40 PM
heres the pics of my truck..Canadian made.. has been in the family since new..
ive had a good start on it...doors are off, all new glass, just about time to do the body work(just the fenders) im leaving the green the way it is
cheers
ID:	305727   Click image for larger version
ID:	305728   Click image for larger version
1928 General Motors Truck - Pontiac Engine kevin351 Antique Autos and Trucks 15 09-24-2015 11:58:27 PM
1928 GMC T20 TRUCK Emergency Brake Lever "ratch" configuration unknown. GMCtrucker Antique Autos and Trucks 2 09-02-2015 06:23:26 PM
1928 Wallis 20 30 Restoration Cody Isaak Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 11-19-2014 03:47:36 PM
1928 Chevrolet Truck Rims Craig A Antique Autos and Trucks 12 07-06-2013 01:40:59 PM
1928 Ford AA Truck Hood garymisner Antique Autos and Trucks 3 04-17-2010 09:23:04 PM
