1925 Buick Standard Six Four Passenger Coupe
this thread has 47 replies and has been viewed 5396 times
Old 09-16-2017, 06:38:06 AM
oldsoldster oldsoldster is offline
Default Re: 1925 Buick Standard Six Four Passenger Coupe
Originally Posted by Oldtech View Post
hmmm. Have you had the tank apart? is it clean and properly sealed?
All fuel components have been disassembled and cleaned in carb cleaner.New gaskets and seals have been installed and screws tightened.My only guess at this point is that I still haven't put quite enough fuel in the tank and when driving down the road the suction tube entrance is exposed to air occasionally.
The Following User Says Thank You to oldsoldster For This Post:
Old 09-16-2017, 10:17:27 PM
Well put mote than $3 worth of gas in the thing and drive it. $7 should get you 2 miles farther before it quits.
Old 09-16-2017, 10:22:00 PM
Oldtech Oldtech is offline
Well. ... sounds like tank might be next to check. Is the pickip tube in good shape and going to within 1/2 " of bottom of the tank? I have seen them corrode off.
Old 09-17-2017, 08:55:26 AM
I really appreciate all the advice you guys are giving me. Oldtech,the fuel tank was removed,cleaned out and sealed at a rad shop. The pick up tube and screen are original and in perfect condition.The fuel lines are new.I will put more gas into it on Monday.
Right now we are going touring with the old car club in the '40 Packard coupe.
Jim
Old 09-18-2017, 01:55:08 PM
Just had the '25 for a 4 mile run and it didn't miss a beat.Had more gas in the tank (!) and tightened the 1 inch nut at the pickup tube.
The 2 front tires went soft on that run.It appears the fellow that restored it bought "NOS" red rubber inner tubes for it.Some NOS components aren't recommended !
The Following 2 Users Say Thank You to oldsoldster For This Post:
  #36
Old 09-18-2017, 02:41:03 PM
Sounds like you are in business. A couple of inner tubes is minor. I wonded if he saved the original air too:
Old 10-04-2017, 11:30:51 AM
Had new tubes installed all around .Rollie Guertin came down and detailed the wheels as per original Pulled her out in the barnyard for a couple of new portrait shots.
Name:	1925 Buick ready to show ! 001.jpg
ID:	292821   Click image for larger version
Name:	1925 Buick ready to show ! 004.jpg
The Following 6 Users Say Thank You to oldsoldster For This Post:
  #38
Old 10-04-2017, 02:00:43 PM
Thumbs up Re: 1925 Buick Standard Six Four Passenger Coupe
What a beautiful looking car! nice find!
Old 10-28-2017, 01:31:59 PM
Now for the first time in 92 years the '25 Buick has it's right front seat back ! The original doctor owner removed it to keep his bag handy.A friend had a jump seat from an unknown 7 Passenger touring car,from which we used the hinges and back rest.A seat base was fabricated to fit into the floor when folded forward.A local upholstery shop closely matched the fabric.It definitely wasn't designed for large people !
Name:	1925 Buick seat 002.jpg
ID:	294572   Click image for larger version
Name:	1925 Buick RF seat frame.jpg
ID:	294573   Click image for larger version
Name:	1925 Buick RF seat.jpg
The Following 4 Users Say Thank You to oldsoldster For This Post:
  #40
Old 12-09-2017, 03:08:27 PM
Anyone driving an early car these days knows that retro turn signals are a must.The '25 Buick had only one central tail lamp.I had a pair of NOS trailer tail lights that match the Buick tail light and mounted them on the spare tire bracket with the existing lamp.The green (!) stop light was a period accessory.
For the front,I purchased a pair of '25-'26 Buick cowl lamps and mounted them on the front spring bushing bolts,replacing the standard nut with a long nut so that a short 9/16 bolt could hold the especially made brackets in place.This way no holes had to be drilled.They show up nicely.
Name:	1925  Buick rear lamps 001.jpg
ID:	297971   Click image for larger version
Name:	1925 Buick front turn signals 001.jpg
ID:	297972   Click image for larger version
Name:	1925 Buick front turn signals 002.jpg
The Following 7 Users Say Thank You to oldsoldster For This Post:
1940 Packard 110 coupe oldsoldster Antique Autos and Trucks 6 07-01-2017 09:53:02 AM
1920 Model T Coupe Craig A Antique Autos and Trucks 270 05-14-2014 05:38:58 PM
1940 Ford Coupe CLips221 Antique Autos and Trucks 6 12-23-2013 09:20:57 AM
