Mack Bulldog
this thread has 53 replies and has been viewed 6045 times
Old 12-02-2017, 09:17:02 PM
I like oldstuff I like oldstuff is online now
Default Re: Mack Bulldog
Excellent fabricobbling! I'd heat the OD of the head area before reefing on it just to hopefully loosen the rust hold on it.
Old 12-03-2017, 03:35:43 PM
OTTO-Sawyer's Avatar
If you cross drill that adaptor you can stick a bar through it for a handle to apply pressure in the direction you want to go with it along with the impact guns raps in that direction.
Kind of like giving an arbor press a whack on the top of the ram while applying pressure.
Might come out easier than you think that way.
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
  #33
Old 12-03-2017, 04:02:34 PM
Jack Innes Jack Innes is offline
With the wrench, a little heat & lubrication I removed 4 of the plugs today!!
I used an electric impact gun that is a little less brutal than the air type. The plugs went hard all the way but did come out.
As I expected the exhaust valve in #4 cylinder is burned. Possibly from being left open for years then run with rust on the faces. The seat looks good & is an insert so perhaps it has been replaced at some time.
Now I need to find 4 or maybe 8 valves with a stem at .490", overall length 10.4" & the head 2.25 diameter.
ID:	297566   Click image for larger version
The Following 6 Users Say Thank You to Jack Innes For This Post:
  #34
Old 12-04-2017, 05:32:05 PM
I just finished pulling an intake valve out & found that it is essentially the same size as the exhaust valve. It is in useable condition so I will likely just need the exhaust valves.
I found Toledo part numbers on both valves; in. T307, ex. S290 (the 9 could be a 0). So far I have not found any listings for Toledo valves.
Old 12-04-2017, 09:10:54 PM
Intake valves have a much easier life as they cooled by the incoming fuel/air charge. As old as your truck is it's probably a really long shot to find NOS exhaust valves for it. Try H&J Machine here in Carrington ND as he has an excellent selection of both obsolete valves and valve blanks. If he hasn't got what you need he can probably whittle you out a set. Contact information is on the Sponsor list.
The Following User Says Thank You to Mark Schneider For This Post:
  #36
Old 12-04-2017, 09:29:38 PM
Thank you Mark. I have already contacted H&J & they got right back to me with a blank that they can make work. It is great to find a company that will respond in good time.
I will pull the rest of the valves & make sure what is needed & send H&J exact measurements. I also need a set of 4 valves for a Reading Standard motorcycle so hopefully they can make them at the same time.
Jack
Old 12-05-2017, 08:48:27 AM
squidtrap squidtrap is offline
Jack- you mentioned using the ATF/acetone mix that i mentioned i swear by.
is that what u always use??? or did u just decide to try it.
was just wondering, everybody has their own special concoction, thanks Ed.
Old 12-05-2017, 10:24:42 AM
Ed, I have been using the ATF mixture for a few years with good success on stuck engines. A couple of years ago I soaked an Associated Hired Man cylinder with it & got the piston out in useable condition. The engine had been in a basement that flooded, totally submerging the engine, every spring for 60 years!
Jack
The Following User Says Thank You to Jack Innes For This Post:
  #39
Old 12-05-2017, 02:01:02 PM
Jack-after that being said, i will stick w/the ATF. always looking for a better solution, keep up the nice work, thanks Ed.
Old 12-08-2017, 02:55:11 PM
H&J will have the valves for the MACK and a set for my 1919 Reading Standard motorcycle done on Tuesday. Great people to deal with!
Jack
The Following 2 Users Say Thank You to Jack Innes For This Post:
Mack Jr's SteamfanMN Antique Autos and Trucks 7 07-15-2014 09:41:05 PM
1930 Mack BL Corey Robinson Antique Autos and Trucks 1 09-05-2012 01:02:07 AM
1926 BullDog Mack Sky Antique Gas Engine Discussion 12 03-28-2010 02:45:47 PM
B 61 Mack James L Johnson Antique Autos and Trucks 3 08-03-2009 11:32:17 AM
Don Mack Linda Bogedain Old Engine Memorials 0 11-26-2005 09:41:49 PM
