Mack Bulldog
this thread has 53 replies and has been viewed 6041 times
Old 10-13-2018, 09:36:57 AM
Jack Innes Jack Innes is offline
Default Re: Mack Bulldog
The Wood hoist is now ready to mount on the MACK.
Does anyone know what viscosity of oil should be in such a unit? The lines are 3/4" & it has a gear pump.
What diameter of cable would be used?
Thank you,
Jack
ID:	320717   Click image for larger version
ID:	320718   Click image for larger version
ID:	320719   Click image for larger version
The Following 5 Users Say Thank You to Jack Innes For This Post:
Old 10-13-2018, 02:37:17 PM
Light hydraulic oil or 10 weight non-detergent.
  #53
Old 10-14-2018, 08:27:27 AM
Peter Holmander Peter Holmander is offline
A fine restoration job Jack. I read your entire post this morning and enjoyed it. Brings back memories of my Dad. When I was 6 yrs old he worked for a construction company that had an old chain drive Mack. The body was steel, but the cab looked similar to yours. It did not have solid rubber tires either. My Mom would set me out at the curb and when my Dad came by the house with a load of gravel, he would stop and take me for a ride in it. At 6 yrs old, I was in heaven. That chain drive truck had a distinct sound. When you heard it in the distance, you always knew that Mack was coming soon.
The Following User Says Thank You to Peter Holmander For This Post:
  #54
Old 01-27-2019, 10:57:44 PM
The MACK AC project is slowed due to weather but I did take it for a drive before the weather closed in. Everything, even the power brakes, worked as it should.
I have found one fender that is coming together slowly but I am in desperate need of a RIGHT fender to match. I can work with an AC or AB fender of the later design in almost any condition. The one I need will look like the green one pictured.
Name:	Mack ac fender.jpg
ID:	327315   Click image for larger version
Mack Jr's SteamfanMN Antique Autos and Trucks 7 07-15-2014 09:41:05 PM
1930 Mack BL Corey Robinson Antique Autos and Trucks 1 09-05-2012 01:02:07 AM
1926 BullDog Mack Sky Antique Gas Engine Discussion 12 03-28-2010 02:45:47 PM
B 61 Mack James L Johnson Antique Autos and Trucks 3 08-03-2009 11:32:17 AM
Don Mack Linda Bogedain Old Engine Memorials 0 11-26-2005 09:41:49 PM
