big block chevrolet head swap
this thread has 18 replies and has been viewed 1068 times
Old 12-13-2018, 11:50:52 PM
Tracy T Tracy T is offline
Default Re: big block chevrolet head swap
Originally Posted by pegasuspinto View Post
tracy, is your 454 throttle body or plenum with port injection?
The Vortec engine is supposed to be an improvement, I have a 1996 vortec 454 and it's OK but not a hot rod. 10mpg no matter what I do lol.
I have throught about what I could do to massage a bit better performance and fuel economy out of it...
Supposedly the 1995 was 230 horse, and the 1996 was 290 horse...
mine is tbi. for what its worth from my research, in 1996 they went away from the dished pistons back to flat top pistons, this pushed the compression back up a bit. also the camshaft seems to run only a few years before a change. i was looking at camshafts for a 1988 they offer a stock replacement that the computer should accept, after all in 1988 they were injected. this camshaft under applications goes all the way back to 1970 and was listed for a corvette. i will see if i can dig that number up and post it, best i recall it was a common camshaft back in the early 70's. no dragster cam by any means. yes 230 hp sounds about right, its a slug for sure! as for the nay sayers just getting a few more ponies do your home work, it is perfectly possible to get another 100+ hp out of this engine using stock parts with no major modifications.
---------- Post added at 10:26:14 PM ---------- Previous post was at 10:15:08 PM ----------
camshaft, sealed power #cs774
---------- Post added at 10:50:52 PM ---------- Previous post was at 10:26:14 PM ----------
here are some interesting numbers, the heads i bought are casting #3856206. 1965/66 396 325 hp.
one other head casting #3872702. i forget the year but its close to the year range from above, 325- 390 hp depending on engine it was used on. 1cc difference in combustion chamber, same valves but larger intake runners. i have examined the intake runners and nothing a port and polish wont make up for. yeah, 230 hp out of 454 cubic inches anybody know what kind of cfm tbi was rated for?
Old 12-14-2018, 02:20:19 AM
Originally Posted by Greg Mosley View Post
Greetings Tracy T. I would consider doing more research on your BBC cylinder head exchange. I don't believe your CC heads will successfully interchange to a Gen V block. GM made some significant water passage changes to the block deck with the Gen V. platform. The 702 castings which I believe you have, tend to shroud the valves. In the day they were designed for a .180 dome piston and higher octane. Your Gen V. heads are OC. and probably have a larger valve diameter. Better flow characteristics. My suggestion would be, install a set of flat tops, an appropriate cam for the application along with proper tuning. As the saying goes (KIS) Keep it Simple. Enuf Said.
good advice here, and i wont be able to check it out until i pull the heads. from what i have read the problem area is the 3 water jacket ports near the lifter valley. there are other changes as well but this seems to be the problem area. any way i dont think i have wasted any money at this point, period correct closed chamber heads arent worthless. from what i have learned with aftermarket heads the problem has been resolved. i wouldnt even bee attempting this if the motor wasnt comming out any way "time for a clutch". we will see where this winds up, may be flat tops with a different cam but it wont be what it was for sure.
Old 12-14-2018, 05:54:57 AM
Glenn Ayers Glenn Ayers is offline
I didn't see if you posted whether this 454 is in a truck or a car ???
You don't want Corvette big runner heads or a Racing style cam in a truck.
Intake air speed (small runners) is what you want for lower end torque.
Large runners & more air flow volume is what's needed for high RPM power.
Most good "Street" Engines are equipped with medium flow runners.
A good example of "Too Much" is no good for the "Street" .. is Ford Boss 429 "Hemi" ... They SUCKED for red light street racing. Built for mass air flow .. & they were terrible low to mid range performers.
"I'll have the Red Pill, thank you."
The Following User Says Thank You to Glenn Ayers For This Post:
Old 12-14-2018, 08:42:18 AM
jgreen416 jgreen416 is offline
If your application is for truck or rv, you might consider a Banks Power System. As mentioned before, max torque is in the lower rpm ranges. Reportedly this type of add on results in added hp and reduced fuel usage. I have seen them on 460 Fords used in rv application, max torque @ 2200 rpm.
JG
Old 12-14-2018, 09:50:52 AM
its in a 3/4 ton pickup with a 5 speed manual transmission, not sure of the gear ratio but it is low. this truck should be a stump puller but its not. the camshaft i looked up was for a 1988 1 ton, when i checked applications list a whole range of years came up including 1970 vette. yes looking for low rpm power and torque, this engine should never see above 4000 rpm, preferably never above 3000 rpm.
Old 12-14-2018, 07:30:27 PM
Then you do NOT want large intake runners.
Old 12-29-2018, 01:56:03 PM
ok so i got the engine out yesterday and the engine on the stand, so i pulled the driver side head and i see where the problem area is. second water jacket back from the front on the intake side of the head. i dont think there is enough material in the head to get a good seal, this is with a 702 head, my other heads that i am thinking about using are @ the machine shop being checked out. oh well if i cant use them their is more than one way to skin a cat.
Old 12-30-2018, 03:32:04 PM
OTTO-Sawyer's Avatar
Personally, I'd just add a good RV Camshaft for low end torque and dual exhaust if it doesn't already have it for better breathing on the top end.
And while you have the heads off anyway, treat them to a good 3 angle valve job.
No need to get crazy with a truck engine.
Old 01-14-2019, 01:44:26 PM
i spoke with a man that has extensive knowledge with this era engine, the problem with power is getting enough fuel to the engine. he experimented with fuel pressure on the tbi setup and unleashed a whole different side of this engine. the problem he ran into is the factory injectors cannot handle the needed pressure, his results were plenty of power with increased fuel pressure but when returned to a idle the injectors couldnt shut the fuel flow down causing a flooding condition at idle. he went with a aftermarket mpi setup and gained power and also improved fuel mileage. this was in a P30 step van loaded with tools, think tool truck like snap on mac etc where he is carring a pretty good load all the time.
Waterloo Boy/Overtime engine block N (SWAP) Billy Donegan Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 07-25-2018 05:18:49 PM
Dang, 3 Broken Head Bolts in Aluminum Block! nothingbutdarts Onan Generators 31 04-05-2018 11:27:57 AM
Unstyled Deere B Head/Rod/Block Torque Colt Edin Antique Farm Tractors 3 12-14-2017 11:51:00 AM
John Deere GP block, head & valves needed eric danielson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 01-26-2012 12:53:18 AM
