My $20 Model T
this thread has 17 replies and has been viewed 1958 times
Old 12-10-2018, 04:25:29 PM
OTTO-Sawyer's Avatar
Photo Re: My $20 Model T
That's $5.00 Better than My "T" Body purchase 25-26 years ago for $25.00
Pulled it back off the shelf and sold it for $250.00 11 years ago then a couple months later I got another $750.00 for my "T" Skid-Engine, "TT" Truck Chassis (which I bought for a Grand with a wooden hearse body on it, which I also resold the Hearse body 15 years ago), and other assorted "T" parts I'd collected over the years.
All I have left anymore is a turtle-deck trunk, flattened out hood, 1 running board, and several buzz-coils (which I'm keeping for hit & miss engines).
Name:	T body on shelf - Copy.jpg
ID:	324292   Click image for larger version
Name:	T left - Copy.jpg
ID:	324293   Click image for larger version
Name:	p - Copy.jpg
ID:	324294   Click image for larger version
ID:	324295   Click image for larger version
ID:	324296   Click image for larger version
Name:	S6300300 - Copy.jpg
The Following 5 Users Say Thank You to OTTO-Sawyer For This Post:
Old 12-10-2018, 08:14:07 PM
Chris Props Chris Props is offline
Default Re: My $20 Model T
Originally Posted by uglyblue66 View Post
look up the serial numebrs and see what year the engine is,that is a 26-7 coil box.
The running boards appear to be 26=7
The chassis,going by the running board support irons is mid 1920 back to about 16 or so.
low radiator is 17-mid 23
As I get a chance I will look it over a bit more.
The engine is a '20 with a 26-27 hogshead. I think the frame is somewhere around 21-23
The Following User Says Thank You to Chris Props For This Post:
Old 12-10-2018, 09:05:04 PM
the 3 rivot hos for each cast iron bracket stopped in mid 20,so it could be a early 21 for sure. alot of that stuff got shuffled at the factory and they would not have trashed a chassis over the holes.Just drill for the newer stamped brackets.
I need to get mine finished so i will feel better about posting pics! It is almost done.
Should be, over 15 years! in the making.
The Model T is a very tough vehical. It was the first use of Vanadiaum steel here in the US and the parts are tough.
The front axle under my pickup was literaly buried in the side ditch of a backroad and I was walking carrying a road sign and tripped over the kingpin bolt sticking up out of the ground!
The Following User Says Thank You to uglyblue66 For This Post:
Old 12-14-2018, 06:18:55 PM
Drove it for the first time yesterday. The coils still need new capacitors and adjustments. That miss should clear up once that is done. I temporarily tied some automotive capacitors across the points until the correct ones come in.
The Following 10 Users Say Thank You to Chris Props For This Post:
Old 12-14-2018, 08:53:35 PM
It is running good! Even though the hoghead is the wrong vintage for that engine,once you drive it,and then drive the correct 1,you will find those wider pedals are A LOT easier to operate. I have found the old roach stomper cowboy boots to be the best shoes to wear driving a T.
As a rule of thumb you adjust the coil points until you get a 1.3 amp draw on each one.
IF you really want the coils A plus working order, send them to Ron Patterson.I think he is in Tennessee. Even if you are driving a running T and you swap to his coils, it is like trading cars. That much difference.
Old 12-15-2018, 07:22:18 AM
Peter Holmander Peter Holmander is offline
Nice work Chris !! My Dad, who passed away some year back always talked about his first car, a model T Ford that he bought for $25.00. He and his friend chipped in and pooled their money to buy it. He said they took the back seat out of it and put a small woodstove in there with the pipe coming out the roof for heat in the winter time. He always talked about how you could crawl under it and replace the transmission bands in about 1/2 hour if you were good at it. Your post brings back memories of his love of that car and all the stories that went along with it. Thanks.
The Following User Says Thank You to Peter Holmander For This Post:
Old 01-24-2019, 09:24:47 AM
Dan Anderson's Avatar
Dan Anderson Dan Anderson is offline
Images: 7
Great success, you had lots of work to do and got it done. Thanks for sharing with us
Old 01-24-2019, 10:41:16 AM
Oldtech Oldtech is offline
You done good!
Ford Model A, Model T Staude Golf Course Conversion and A Twin City cerwin Antique Farm Tractors 0 01-12-2017 06:49:05 PM
Briggs Model N Collection, as well as a Model U, Model I, and a 6s Bowtiebutler956 Small Air Cooled Gasoline Engines 6 06-28-2015 01:43:02 PM
Maytag Model 92 Oiler Ball Oil/Etc. (New Model 92 Owner Questions) KubotaDiesel Maytag Engine Collectibles 7 11-17-2013 04:35:25 PM
“MODEL GAS/KEROSENE TRACTOR DISPLAYS” @ the Cabin Fever Expo Model Engineering Show Paul Spence Antique Gas Engine Discussion 1 12-23-2012 08:46:28 AM
Briggs Model PB Crank (For Moto-Mower Detroit Model) Jonathan Widelo Small Air Cooled Gasoline Engines 0 02-05-2009 02:43:17 PM
