1977 dodge pickup parts source
this thread has 19 replies and has been viewed 693 times
Old 01-30-2019, 05:49:24 PM
Alan Svanes Alan Svanes is offline
Default Re: 1977 dodge pickup parts source
Years ago working on ignition switch on a 79 Dodge I found out that the steering column was the same as a Chevy. Maybe another company also made the heater core.
Alan
Old 01-31-2019, 01:04:37 AM
Oldtech Oldtech is offline
A radiator shop should be able to make one up using your old tanks. They can get bulk heater core... at least they used to.
Old 01-31-2019, 01:19:13 AM
Motorhead's Avatar
See if it looks like this https://www.ebay.com/itm/New-Heater-...frcectupt=true
The Ram Charger used most stuff from the dash forward as the trucks.
My 1939 WILLYS Pickup.
Bought in 1971
Old 01-31-2019, 07:37:12 AM
Tracy T Tracy T is offline
cold as all get out and my shop is full so i am working outside on this one, warmer weather coming monday may get a chance to look at it then. i knew this was going to happen, it all ways does you either have nothing to do or it all rolls in at once. three motors to pull two to rebuild, a livestock trailer that needs brake work and basically a total rewire and a f350 needing brake work. my stuff will have to wait.
Old 01-31-2019, 07:03:59 PM
OTTO-Sawyer's Avatar
Not knowing ALL of the particulars, like what model of truck or engine size, I was somewhat limited in my search, but have you tried these guys. . .
http://www.completeradiators.com/par...HeaterZZCores/
Or These. . .
https://www.partsgeek.com/catalog/19...ater_core.html
I just went with a 77 B100 on both searches to see what showed up.
On the second one there, it's interesting to see that Without AC the heater core is $110.43 while one WITH AC is only $77.43
Looks like they have 5 on hand, though taking a second look I see they are listed as "Rear" (possibly for a Ramcharger ?)
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
Old 02-01-2019, 09:36:16 AM
i am not up to speed on this era truck but i know it has a 360 engine and from my limited knowledge i think it is a w series, w meaning 4wd i assume. it is a 100, at least thats what the fender badges say. has power wagon badges on the hood, and adventurer on the truck.
---------- Post added at 07:43:30 AM ---------- Previous post was at 07:35:50 AM ----------
first link has one w/o a/c, second link i came up with nothing.
---------- Post added at 08:36:16 AM ---------- Previous post was at 07:43:30 AM ----------
learning about these, B series= van, d series = 2wd truck, and w= 4wd truck, 100, 200, etc =1/2 ton 3/4 ton and so on.
Old 02-03-2019, 08:11:27 PM
i got the old s&^% box dodge running today, i have owned two over the years and swore them off after the second one! but as they say third time is a charm, i may just keep this one.
Old 02-03-2019, 09:01:21 PM
drumfield drumfield is offline
I have a '76 Power Wagon, came with a 400/2v auto. It's also a Club Cab Adventurer series. 400 was trashed, replaced with a 440/4v out of a motorhome. Got to fix both fuel tanks, and replace the dash and under-dash wiring harness, r&r heater core, repair a/c, and a few other minor things.
Be careful with the shifter for the TC. Easy to break, hard to find.
I think they had a "P" series as well. It was a "van turned into a pickup". I believe it was also called a 'forward control'.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." Albert Einstein
The Following User Says Thank You to drumfield For This Post:
Old 02-03-2019, 09:30:01 PM
thanks for the heads up on the TC shifter! i friggin hate spell check!!!!! i know i spelled shifter right both times. if i didnt some body please correct me.
Old 02-03-2019, 09:44:01 PM
Looks good to me. That's how I spelled it, and spell check told me I was wrong as well.
Dodge 1941 Pickup Rebuild Benjamin Roth Antique Autos and Trucks 93 02-28-2017 01:37:54 AM
Need a parts and repair manual for 1977 5.0 CCK wxyoung2008 Onan Generators 3 02-01-2014 02:37:26 PM
A box for a 1938 Dodge Pickup High Voltage Antique Autos and Trucks 2 11-25-2011 08:37:42 PM
need parts dor a 36 dodge pick up Canadian made Antique Autos and Trucks 2 12-11-2006 01:09:28 AM
Here is a good source for FM "ZC" parts AND late model Witte parts Doug Waggonner Oil Field Engines & Related Equipment 2 09-13-2005 09:40:08 AM
