'56 International 4WD Brush Truck Series S-140
this thread has 53 replies and has been viewed 19434 times
Old 04-02-2007, 12:14:55 PM
Default Re: '56 International 4WD Brush Truck Series S-140
Binderbooks.com is supposed to have manuals for everything IHC (reproductions, I assume, but the info's what's valuable) and presumably would include brake work/special precautions/idiosyncrasies. For users experiences there's oldihc.com. Good luck.
Old 04-02-2007, 05:16:21 PM
John Hanson John Hanson is offline
Beth, shoot an email to Terry Dovre.. he'll be able to help ya most likely with any brake stuff..
I just PM'd you his email.
JH
Old 04-02-2007, 08:31:54 PM
Beth V's Avatar
Beth V Beth V is offline
Thanks everyone...I'll keep you up to date as my husband digs into it!
Beth
Old 04-02-2007, 11:30:48 PM
Rick McKay Rick McKay is offline
Good evening,
I should knock on wood. I have a '56 S-110 2wd with 150,00 miles that I bought in '94 with a blown wheel cylinder. I rebuilt the wheel cylinder, and drove it through the rest of that year. I have not licensed it since, but use it around the shop for odd jobs during the summer. Crazy thing is, I haven't had to add a drop of brake fluid since I fixed that wheel cylinder!!!
Just watch........ now since I mentioned it, the brakes probably won't work when I take the old binder out of mothballs this month!!!!
Old binders are fun!!!!
Rick
Old 04-03-2007, 12:10:43 AM
Exclamation Re: '56 International 4WD Brush Truck Series S-140
Beth,
I loved my old L-120 The original engine, a Silver Diamond 240 was shot when I bought it The early SDs (49-52) were good for 45 MPH, then you spun the poured bearings! The crank , on mine, was cut to 100 under, because the engine was run with NO bearings! I priced out a rebuild, after the Japanese bought out IHC, the prices went to hell in a handbasket! The later SDs (53-55) could get 50 MPH, as they had modern inserts. The next thing to break was the sodium filled exhaust valves! In '56, IHC redesigned the entire engine to todays standards - the Green Diamond engine. (probably what's in your S series, but I'd make sure) I had located a 55 SD 240, but the IH dealer wanted $1,000 for it, with NO guarenty as to if the engine was still good! I ended up modifying the engine mounts, and installed a '66Chevy 250 6 cylinder and a 3 speed trans. It cost me only $20, at the time, for a drive shaft shop to re-manufacture the front shaft to fit the Chevy trans to the IHC shaft, and install a new center support bearing. I used the hell out of that poor truck, And for the $50.00 I paid for it, it was the best truck I ever owned. I had people looking at it all the time! I once got pulled over by a state trooper, just because she wanted to look at it! Her father had owned one like it when she was a kid. One other item that saw a lot of wear was the front end king pins. (the part that the steering knuckles turn on. Mine were usually shot within 1 year of installation. This was probably due to the fact that the poor old L-120 spent most of its life at nearly double its builders intended speeds With the chevy engine, a modified intake manifold (I installed a 2 barrel carb from a california Chevy 283 V-8 engine), and a good on the truck, wheel spin balance, it would cruise all day at 70MPH, and it got 18 MPG! I would not do this with your S-140 though. My truck was IHC green, with black trim, and the bed interior was IHC red. I had Chrome rails around the bed, to dress it up. The truck had a 141 Wheel base, 750-16 split rim wheels, a 410 Timkin rear end IHC Special built I think - it was a devil to get parts for), 8' bed, dual fuel tanks, 3/4 ton running gear, and at rest, the running boards were 14 inches off the ground! As long as the wheels were balanced, she ran at highway speeds just fine, Once the wheels became unbalanced though - look out. Balancing them was a real pain. After replacing the king pin bushings (I had it down to a science - both pins and all bushings, bearings, and seals in under 3 hours!), I had to rebalance everything. The rears were not to bad. I just bolted on the balancer, locked one wheel, and ran the truck thru the gears until it hit about 40 to 45 MPH (wheel speed about 85 MPH or so. Set the balancer intil you could stand a new nickle on edge on the fender, and you were set. The balancer told you how much weight, and where. The fronts were not that easy. First the durms had to be balanced. First the tires and rims were removed, and then the balancer was installed on the drum A long V belt was then placed on the OD of the drum, and was then run around the barrel of the spin balancer motor drive. This thing was a 2 HP repulsion start variable high speed motor (10,000 RPM), with a 6" diameter aluminum drum on the output shaft. You had to be real careful spinning up the drum, as if the belt ran off, the motor would snap it instantly, and send pieces all over the shop, where I worked. Anyway, I installed new drums on the truck, one year, and it took nearly 5 punces to balance them alone! they wer really poor castings!!! After the drums were balanced, the tires and rims were then mounted up, and then the balancer motor drum was used as a friction drive, directly on the tires them selves, If all was done right, I could get 85 % motor speed, without smoking out the shop too much, and balance the tires just like the rears - After pulling the motor away from the tire, I could balance a nickle on the fenders! The old IHC sure could ride smooth with all 4 tires set up! As i said, due to it's age, I had a lot of maintainance, but I loved every minute of it My only regret, that I could not find the parts I needed to repair it after it was wrecked. I have a new project now though - a 1963 Chevy C-30 Custom Special. It was purchased by our local Fire Dept, new, and in a round about way I ended up with it! Same problem as you - NO BRAKES All 4 wheel cylenders NFG, ans all steel brake lines shot as well. One plus, the guy I bought it from just put in a new master cylinder!!! Keep us advised as to your progress!
Old 04-03-2007, 12:24:03 AM
Beth V's Avatar
Thanks Andrew!
More rain is predicted this week so the hubby will probably attack it. He thinks an aluminum diamond plate bed would be nice......................
It seems like Dad said it would only make about 45mph, but that may be more the tranny than the motor...however until it has BRAKES, we are not going in there!
I've related much of everyone's comments to him, but he'll have to pull it apart himself & then apply what has been said. All I know is that when you push the brake pedal...it goes to the floor & NOTHING!
Thanks!
Beth
Old 04-03-2007, 05:26:45 AM
MoRo's Avatar
MoRo MoRo is offline
You're right about the (lack of) speed. Your ol' girl has some pretty steep ratioed diffs, as it's a "Tonner". If you were to drop the transfer case into low, and the tranny into "Granny" gear, you'd darn-near have to drive stakes to see if you moved! The setup you have is great for crawling around hills and other rough terrain. It'd also move a house, if you hooked up to it.
Andrew's right on with his assesment of IHC engines of the era your truck comes from. You didn't go very fast, but you got there!
My dad still owns a '54 R-160, though it's missing some major componants (the engine being one of them). It took a long time to run a load of grain to the elevator.
Later
Old 04-04-2007, 10:55:07 PM
Beth V's Avatar
Monte,
I guess we could put it in low range & go tail to tail with a steam engine.............but I bet my Dad would come back to haunt me! I'm not sure WHICH he would route for?
Beth
Old 04-05-2007, 09:35:02 AM
MoRo's Avatar
Lock 'er in 4-Lo and go tail-to-tail with one of these fancy-schmanzy new Diesels and pull 'em. My money's on your ol' Cornbinder!! (Specially if you fill that water tank about half-full!
Old 04-05-2007, 12:22:06 PM
Beth V's Avatar
Monte,
I bet it would work even better if I latch the winch onto something & have that be my "magic lever!"
Beth
Video For any International Truck fan Mark Mohney Antique Autos and Trucks 4 02-24-2008 08:37:17 PM
1975 IHC 200 series fire truck engine? Tom Cwach Antique Autos and Trucks 1 11-03-2007 06:56:44 PM
1914 International Truck Info Needed Bob Hanauer Antique Autos and Trucks 3 08-29-2007 09:04:07 AM
Old IHC International truck David Nicolson Antique Gas Engine Discussion 4 02-03-2005 07:28:50 PM
INTERNATIONAL ENGINE TRUCK DICK STAATS Antique Engine Archives 5 07-15-2004 08:05:41 PM
