An Onan JB Performance Question
this thread has 424 replies and has been viewed 12498 times
Old 08-06-2017, 12:02:11 AM
Jim McIntyre's Avatar
Default Re: A JB Performance Question
Doesn't seem right, Leon.
Here' how mine behaves. I had run the set for about 60 seconds before this video, so it was't really warmed up.
https://youtu.be/0vERaGEr6ac
The Following 3 Users Say Thank You to Jim McIntyre For This Post:
Old 08-06-2017, 01:28:38 AM
len k len k is online now
Leon........ here's a test you can do to check demand reg, to eliminate variable of air diffused into nat gas in it. Energize nat gas solenoid and blow into vent of demand reg for 5-10 sec. That way propane flow will purge demand reg of all air. Then start engine and do your transient response load test.
Old 08-06-2017, 09:06:09 AM
Leon N. Leon N. is offline
Jim I like the way you shut down your JB. However, not sure what else I got from your brief video. I would like to see how your JB responds (recovers) when dumping a FL on it. Could not tell from your video.
lenK yes, by forcing more full into the carburetor, my JB will start quicker. If I try this while running "it don't like that". Not practical to blow into the Garretson when load is applied. Surely you did not mean that. Nothing is perfect.
I think my problem may be pointing to the old, lazy Garretson regulator. The problem seems worse in the Winter. I do have Garretson repair kit.
I agree with Wayne, and will probably leave well enough alone- and that probably goes for the starter as well. But these little things still irk me.
There must be some JB users out there who have seen theses problems. Oh well.
Old 08-06-2017, 09:19:48 AM
armandh armandh is offline
problem overview
cold air is more dense than warm air
thus the start up mix is lean
[gasoline] this sort of cold to warm engine variation not corrected by the automatic choke was covered by a slightly rich mix
now days it is the mass air sensors that help control the mix [tighter control but more stuff to have issues]
gen-sets that had to provide full output at start usually had heaters 24/7 or were kept "indoors"
so if you can't wait for warm up, keep it warm, which can be costly.
Old 08-06-2017, 09:21:41 AM
JohnnyC JohnnyC is offline
Leon, do you want to see what happens when a full load (7.5 kw) or when 4 kw is dumped immediately on a JB when started cold? I think dumping a full load on a cold anything is not wise. I would think 4 kw dump on a 7.5kw JB when started cold is realistic and reasonable. Time permitting today (Sunday) I will do that test and put it on video. First, I have a few time consuming chores to do such as some maintenance house painting and reconfigure my father's desktop PC. Also, this will be done on propane. Way too much to disconnect in order to roll the JB to the NG fuel source at the house.
***Let me know if you want me to run the test.
*** UPDATE: I just watched Jim's video (Jim, you got a nice and healthy sounding JB).... What I plan to do is start my JB with a 4kw load on it at start up. It may sound crazy, but in reality if a circuit was already loaded and running from the Utility then suddenly a power failure hit, my ATS would immediately signal the generator to start and transfer the load in a blink of the eye. SOOOOoooooo, this is how I will run my test which is different than Jim's demonstration. Is that what you are looking for Leon??
JohnnyC
New Jersey
Old 08-06-2017, 09:49:53 AM
At time 00:30, I switch on a full load. You can tell from the sound of the engine. You can also tell the governor responds instantly, doesn't drop much in speed, and is not unstable. Isn't that what you asked about, Leon?
Leon - what happens when you open the mixture screw on your carb a quarter or half turn? Does it get better or worse?
Old 08-06-2017, 09:54:25 AM
These are al good valid comments from you guys. I agree, I would not dump a full load on my JB from a cold start. Same goes for my cars, I do not drive at 65 MPH from a cold Winter start. That being said, my real concern is in the Summer time starting that 3 ton AC from a cold start. I would never do that but I have been playing around with a 4 Kw resistive load bank and I notice the JB responds differently when 4 Kw is dumped on the cold machine vs when it has been running for a few minutes. True, I am burning NG not propane or gasoline which is ~ 2.5 x more powerful.
Johnny I would be interested how your JB and other user's JBs react to the following 1966 Onan "Performance Certified" spec sheet which I have the original copy received from Onan back in 1970. It says the following and I quote:
UNIT PERFORMANCE: Frequency Regulation. " Droop governor - 5% (3 cycles) maximum, no load to rated load. Recovers to steady-state operation in less than 2 seconds on application or removal of rated load in one step".
I would be willing to bet there are not many operational JB's out there today that meet this requirement, especially if operating of natural gas which has a much lower heat content than either propane or gasoline. Onan says to derate 20% on NG.
I suspect Onan subsequently dropped this requirement. My JB will meet this requirement @ 4Kw. Have not tried it at 7.5Kw or even 6 Kw because, I do not have such a load except for the central AC which draws about 88 amps on start up. But I worry from time to time because I also use rotating back emf motors to help the JB.
Are you guys aware of this JB recovery spec? I have not seen much discussion about it.
I would say this however, if your JB can meet the 2 second recovery spec, then it probably is a well tuned, well operating gem!
It would not be correct to run this test @ 7.5 Kw on NG due to the lower heat content of NG. However, try this test on propane or gasoline fueled JB and see what your stop watch says. Would be interesting to know.
One more thing, recovery to SS operation to me means the JB must be back within the 3% voltage and 5% frequency tolerances to be a valid test.
Old 08-06-2017, 10:13:07 AM
Leon, my comments are in bold red below
--- snip ---
I may have misunderstood what you originally wanted tested. From the Onan Performance Certified Statement it does not say anything about a cold start no load and immediately banging it at full load. Either way I can test since as already mentioned once the ATS starts the generator it will bang it at whatever load is present on the circuit, if any
I would be willing to bet there are not many operational JB's out there today that meet this requirement, especially if operating of natural gas which has a much lower heat content than either propane or gasoline. Onan says to derate 20% on NG. True and it is silk screen printed on one of the tins too (at least with the 1991 models).
--- snip ---
Are you guys aware of this JB recovery spec? I have not seen much discussion about it. I never read the spec, but at times I only do selected reading
I would say this however, if your JB can meet the 2 second recovery spec, then it probably is a well tuned, well operating gem! A test will tell all and looking forward to doing it on video hopefully today
It would not be correct to run this test @ 7.5 Kw on NG due to the lower heat content of NG. However, try this test on propane or gasoline fueled JB and see what your stop watch says. Would be interesting to know. NG test will have to wait on my end. As already mentioned, I got way too many things hooked up to my JB at the moment and would be a p.i.t.a. to disconnect in order to roll the JB to the house for a NG hook up.
JohnnyC
New Jersey
Old 08-06-2017, 10:15:44 AM
Motorhead's Avatar
Quote from Onan unit performance: "UNIT PERFORMANCE: Frequency Regulation. " Droop governor - 5% (3 cycles) maximum, no load to rated load. Recovers to steady-state operation in less than 2 seconds on application or removal of rated load in one step".
As I read this, it doesn't say that the unit has just been started and is cold or at Operating temperature. Doesn't say what fuel either.
I have an option on my Garrettson which is a 12 volt solenoid primer. I have a momentary contact switch on my generator control panel. I energize it for 2-3 seconds and my set starts right up. I wait about 1 minute before loading just to let the engine warm and lubricate. I can then flip my transfer and it will start my 3 ton A/C and usually the refrigerator at the same time. I have a gas valve like Jim M has and often shut mine down the way he did on the video. My set is close to my gas meter with a 12 foot hose between the meter and generator.
Leon, How long of a gas pipe do you have between the gas meter or house supply and your generator shed? Could there be some problem where the line isn't all the way purged with all natural gas vapor after sitting?
Does the symptom change say if you fire up the JB, run it for 30 seconds, shut it down, restart it then try your test?
My 1939 WILLYS Pickup.
Bought in 1971
Old 08-06-2017, 11:47:33 AM
MBB MBB is offline
Leon even the Transfer switches have a time delay for the motor to warm up. See attached.
Farmall H Performance Help The motor kid pig guy Antique Farm Tractors 2 08-14-2015 12:19:40 AM
US Injector #4 Performance ChickenSoup Steam Stationary Engines, Traction Engines, Steam Boats 7 08-13-2014 10:42:03 PM
Onan J-Line Engine Performance Curves Leon N. Onan Generators 7 04-07-2010 09:42:07 PM
Battery Performance Nubian Onan Generators 12 03-04-2009 01:11:21 PM
