Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
Titan Generator Questions
this thread has 15 replies and has been viewed 1833 times
Old 01-12-2018, 10:03:10 AM
Handyhiker1 Handyhiker1 is offline
Default Re: Titan Generator Questions
I know it is China built and not kidding myself. I just like to learn more about generators in general so I pick up, fix and sell some China ones. I try to never have that much in them that I can't recoup on parts sales.
I just find it interesting that unless people really figure out the amps/volts/watts, this is a useless rating on the generator. Most folks would expect the manufacturer to list the actual usable watts.
The old days, you bought a 4000 watt generator and it would put out 4000 watts all day long, now you buy a 4000 watt generator and should expect it to put out 75-80% of the rated output. I have been able to get some clones to pull 90-95% of rated load for extended load tests. It does require some work and no way right out of the box. Also, my extended load tests are not 12-24 hour tests, they are more in the 2-3 hour window.
Actually going to test a 3000 watt Snap-on today that I finished up last night.
What is funny is I test my stock Onans at 110% of rated output, stock clones at about 80% and modified at 90-95%.
Old 02-08-2018, 07:15:09 PM
@Handyhiker1 - I crossed over to the dark side in a moment of weakness and actually bought a "6500 watt" Chinese generator with the pull rope broken and carb gummed up so much that the choke and throttle plates would not move.
Much to my amazement, after freeing up the carb plates and a repair of the rope, it started with a shot of starting fluid. After some wheezing, it took off on the old gasoline left in the tank since who-knows-when and actually made 120v power.
I think it might be worth changing the oil in.
Old 02-09-2018, 12:51:22 PM
Originally Posted by Wayne 440 View Post
...I think it might be worth changing the oil in.
Discovered that it holds only 2.5 cups of oil. I decided to "invest" that much more $ in it. The old oil looked like weak coffee and was about the same viscosity.
Old 12-29-2018, 06:50:19 PM
I know this is an old thread but looking at this generator again after just leaving it sit in the basement for the last year. I must admit that I got a little discouraged when I could not find needed info on it. Searching again on line, I actually did find a wiring diagram. Also found where the vacuum line hooks to.
So now I have gained a little interest in it again. So hopefully I will have enough information now to get it back together. I checked and it does have spark so now to figure out the wires and mount the carburetor and see what happens.
Old 12-31-2018, 11:31:33 PM
FWIW, the Chinese set I had turned out to run OK and (just barely) produce rated power.
I put some fresh gasoline in it, ran it for an hour or so, then listed it for sale. About 3 days later it left with its new owner, making both of us happy.
Old 01-06-2019, 05:10:48 PM
Had some time today to work on the generator. Got most of it back together but then found out that the wire diagram I have is the wrong one. I still have one wire that I don't know where it goes. Also not sure if the other wires are all connected correct.
I still need to get an in line fuel filter with step barbs because the carburetor takes a 3/16 fuel line and the pet cock is 1/4 or 5/16. The other thing that still needs to be done is the angle of the muffler when bolted tight to the engine, throws off the other mounting holes.
Got a few pictures of the generator back together and decided to call it a day.
ID:	325847   Click image for larger version
ID:	325848   Click image for larger version
ID:	325849   Click image for larger version
The Following User Says Thank You to Handyhiker1 For This Post:
Titan 8000 Generator Ceder Generators & Electric Motors General Discussion 4 10-05-2017 10:19:24 PM
Titan 7500D Generator Olf20 Lighting Fixtures, Switch Panels and Meters 2 08-22-2015 06:29:52 PM
4hp Titan Questions Dan Moore Antique Gas Engine Discussion 3 05-08-2015 10:46:48 PM
Titan Industrial TG5500D generator nothingbutdarts Generators & Electric Motors General Discussion 14 08-29-2014 09:24:56 PM
Titan TG-8000 Generator, no output. rcowboy Generators & Electric Motors General Discussion 27 11-22-2012 10:19:18 AM
