Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generators & Electric Motors General Discussion > Honda, Yamaha, Kawasaki, Isuszu Generators
Honda, Yamaha, Kawasaki, Isuszu Generators Restoring, maintaining and operating Honda, Yamaha, Kawasaki, Isuszu, and clones.
Cleaning Slip Rings
this thread has 6 replies and has been viewed 566 times
Old 03-10-2018, 09:06:01 AM
powerking powerking is offline
Default Cleaning Slip Rings
What is the best thing to use to clean the slip rings?
Old 03-10-2018, 09:17:18 AM
Kevin K Kevin K is offline
Default Re: Slip rings
I like 3M Scotch-Brite heavy duty scour pads. They are non conductive and clean well.
Old 03-10-2018, 02:47:31 PM
Default Re: Cleaning Slip Rings
Be sure to lift the brushes off the rings before you clean them, so no grit gets imbedded in them. After cleaning, wipe the rings off with a clean white cloth before re-installing the brushes.
Old 03-10-2018, 04:22:36 PM
Motormowers's Avatar
I use fine Scotch Brite then buff them with crocus cloth. After that a quick shot of electromotive spray to remove any film on them
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
Old 03-10-2018, 05:50:07 PM
georgineer georgineer is offline
As an apprentice I was taught never to use carborundum paper on slip rings or commutator bars, but fine sand paper. Apparently the carborundum imbeds itself in the copper and carries on doing its job after you think it's all been cleaned off.
George
Old 03-10-2018, 09:11:05 PM
turbo's Avatar
turbo turbo is offline
I work on locomotives for a living and when we have a rough slip ring we put a stone under one brush and start the unit up. It works great. There are 3 different grits and the final one is white and almost looks like talcum powder. But at idle these are only turning 1-200 rpm. I donít know how well this would work with a small generator??
Old 03-10-2018, 11:30:19 PM
Email NOT Working
I have cleaned up many by running the starter while holding a stone to them while running.
Generac 16 kw Slip Rings Tony Rye Generac Generators (SEARS, etc.) 5 02-06-2018 08:06:20 AM
Cleaning Slip Rings on Onan smaller generators tdarden Onan Generators 7 02-17-2014 02:19:49 PM
Slip Rings 69commander Kohler Generators 2 12-09-2010 03:07:38 PM
Polishing/cleaning armature & slip rings Joe_Roach Onan Generators 6 06-20-2010 04:29:09 PM
Cleaning Commutator & Slip Rings mantta Onan Generators 7 03-14-2010 10:23:48 AM
